throttle cable?
Old Oct 16, 2008 | 12:12 PM
~jack~'s Avatar
throttle cable?
So i changed the oil in my runner the other day, and when i started her back up she was running at about 3 grand idling. Shut her down and after a bit of messing with it it turned out the cable was kinked. Unkinked it and it ran fine for a bit. Later turned it on and the opposite was happening. Would not stay at idle, as soon as you let off the gas it would drop rpms until it stalled. While messing with it again i blew a relay turning it on so am awaiting that to mess with it more. pretty sure this is the throttle cable but am i wrong?
Old Oct 16, 2008 | 12:27 PM
abecedarian's Avatar
so, the oil cap is tight and the dipstick is in good too? sounds dumb, but vacuum leaks can occur if not.
Old Oct 16, 2008 | 12:33 PM
~jack~'s Avatar
k thanks for the heads up ill check for sure
some drunk guy
Aug 3, 2021 06:09 PM
Williamemslie
14
Oct 5, 2015 09:28 AM
Sam hain
19
Sep 30, 2015 08:25 AM
Shaun Crystal Gomban
Sep 20, 2015 11:16 PM
toyotafreak98
Sep 10, 2015 02:57 PM
