Gears And Tires ?.
Old Oct 14, 2008 | 07:59 PM
myyota's Avatar
Gears And Tires ?.
I will be running 37" tires on my 86 4Runner, and i have duel cases, will 4.88 gears work ok for my set up ?, i know 5.29`s would be better but i just don`t have the money for that right now.
Old Oct 14, 2008 | 08:02 PM
gte718p's Avatar
It depends...
Search, read, this has been discussed to death. It all depends on what you want out of your rig.
Old Oct 14, 2008 | 08:22 PM
Jay351's Avatar
Yes it will work. But it will work better with 5.29's. Plain and simple.
Old Oct 14, 2008 | 08:24 PM
tc's Avatar
tc
Trail only or will you be driving it on the road?
Auto or manual?
Old Oct 14, 2008 | 08:39 PM
myyota's Avatar
Auto or manual?
I will be driving it on the road some, it has a manual trans with duel cases.
Old Oct 14, 2008 | 08:47 PM
Matt16's Avatar
31"-4.56
33"-4.88
35"-5.29
35+" 5.71
I think 4.88s are going to be brutal with 37" tires.
Old Oct 14, 2008 | 08:53 PM
myyota's Avatar
Originally Posted by Matt16
31"-4.56
33"-4.88
35"-5.29
35+" 5.71
My truck was an automatic (now manual) so it has 4.30 gears now, so i would think that 4.88 gears would be a hell of an improvement over the 4.30`s ?.
Old Oct 14, 2008 | 09:32 PM
Jay351's Avatar
No they wouldnt..
Old Oct 14, 2008 | 09:54 PM
sh0kk86's Avatar
I guess it cant be to much worse than 33's on 4.10's
Old Oct 14, 2008 | 10:01 PM
86tuning's Avatar
13% difference, which is not much.
5.29 would be 23% difference, which is a bit better. And the price of 5.29 gears is the same as 4.88 gears.
Old Oct 14, 2008 | 11:04 PM
Matt16's Avatar
Oh yes, it can be much worse. You'll be taking the engine out of its torque band. Let me give you an example. I had 31" tires with 4.10s. That's actually pretty common and accepted to be fine. Factory 31s came with 4.56 (5spd). There is a particular hill near my house about a kilometer long and a pretty steep grade, with 4.10s, the fastest speed I could maintain was about 70km/h, I regeared to 4.56s and now I can come out the top at 100 km/h.
The gearing advantage is only about 10%, yet I was able to see an increase of 30% in terms of speed on this hill. This is because the engines in our trucks have pretty narrow torque bands and the gearing from the factory is calculated to make the most of the torque/ power available.
Why not do an upgrade you can afford to do well.
Old Oct 15, 2008 | 04:04 AM
gte718p's Avatar
I see top speeds in the 40's in your future. Offroad with two case you'll be golden.
Old Oct 15, 2008 | 04:12 AM
Spence1016's Avatar
i dont understand why you wouldn't get 5.29s unless your getting the 4.88's for free? you say you have 4.30's now so that means your yet to replace them, why not replace them with what's best if they cost the same?
Old Oct 15, 2008 | 10:18 AM
Matt16's Avatar
5.29s are not enough for 37" tires. You need to go all the way up to 5.71. Not only to you have to deal with the large diameter tires, but there's the mass of those meats to contend with. Interco says the 37x14R15 weighs 69lbs. The 31x10.5r15 BFG T/A KO weighs 43lbs.
Given that 1lb on the tires is equivalent to 10lbs added to the body of the truck, going from a 31 to a 37 is 26lbs difference per tire which translates into and extra 1040lbs your hauling when accelerating. Gearing needs to compensate for that as well.
Old Oct 15, 2008 | 10:38 AM
Team420's Avatar
4cyl or v6? If you have 22re, you will most def want 5.71.... you might be happy with 5.29 on v6...or only slightly unhappy with 4.88...but if its a 4 cyl.... you want the 5.71's. just My opinion.
Old Oct 15, 2008 | 01:37 PM
black diamond's Avatar
5.29 is perfect IMO for 37's, street and trail, 4 or 6 cyl.
XtraCab
Apr 12, 2020 05:25 AM
coffey50
Jul 28, 2015 10:55 AM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
PlayAwhile
Jul 20, 2015 11:36 AM
