Engine Question
Old Oct 18, 2008 | 04:50 AM
clayton_CJ7's Avatar
Engine Question
I am working on my 94 Toyota with the 22 RE and when i call to order parts they say it has a 2400 motor, is that the same thing i thought it was a 2200? Also i am replacing the head gasket and need to know the torque sequence for the head bolts and torque specs. Thanks for the help guys.
Old Oct 18, 2008 | 05:34 AM
'884Runner's Avatar
Yes, it is a 2.4 liter or 2400 cc. The 22R/E is just a designation and does not reflect displacement.
Old Oct 18, 2008 | 07:17 AM
jason191918's Avatar
X2....
Old Oct 18, 2008 | 09:09 AM
Thanks guys, anyone know the torque specs?
Old Oct 18, 2008 | 09:16 AM
RatLabGuy's Avatar
I believe the 20R motor (from 70s, maybe some in use eraly 80s?) was 2.2L or 2200 CCs.
Old Oct 18, 2008 | 09:25 AM
116hp @ 4800
140ft lbs @ 2800
Old Oct 18, 2008 | 09:27 AM
toyminator2000's Avatar
Not enough to register on a dyno.
Old Oct 18, 2008 | 09:43 AM
Oops...I just realized you wanted the torque specs, not the torque specs.
58 ft lbs
Tighten inside to outside and do it in 3 passes w/ the last pass being 58 ft lbs
Old Oct 18, 2008 | 09:44 AM
mmcpeck's Avatar
I think he meant the torque specs for torquing the head down after doing the HG.
Old Oct 18, 2008 | 09:45 AM
Found it.
page 20
http://www.ncttora.com/fsm/1993/engine/7cylinder.pdf
mmcpeck's Avatar
Oops just beat me jason.
Old Oct 19, 2008 | 04:31 AM
Thanks again guys
bigjstang
Jun 2, 2025 03:56 PM
kazuya2416
Apr 5, 2024 02:17 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Cplmike
Jul 8, 2015 08:47 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
