Red and white wires off distributor
Old Oct 18, 2008 | 11:41 PM
GTEC's Avatar
Does anyone know which wire is the positive and negative off a 1986 carb'd 22r distributor. I'm installing an MSD 6A and don't know how to test the polarity of the magnetic pickup. Thanks!
Old Oct 18, 2008 | 11:46 PM
abecedarian's Avatar
neither is hot nor ground, per se. they send a signal to the ignitor.
Old Oct 18, 2008 | 11:48 PM
and you should be pulling the trigger to the msd from the ignitor
Old Oct 19, 2008 | 12:10 PM
GTEC's Avatar
sorry, i should of been clearer. the igniter is broken. i am trying to use the magnetic pickup in the distributor to trigger the 6A. Which wires hook up to the green and violet off the msd?
Old Oct 19, 2008 | 12:14 PM
courtesy of
MSD 6A without ignitor:
Heavy red wire = Battery 12V +
Heavy black wire = Ground
Small red wire = switched 12V (beige wire originally to ignitor)
Small white wire = NOT USED (make sure it won't ground on body)
Small purple wire = violet wire from distributor
Small green wire = white wire from distributor
Small orange wire = + side of coil
Small black wire = - side of coil
Old Oct 19, 2008 | 12:17 PM
it was also mentioned that you may have to retard the distributor 1 tooth to get the timing back down to spec
Old Oct 20, 2008 | 02:59 PM
GTEC's Avatar
thanks!
the1998sr5
15
Jul 14, 2020 08:35 PM
montanatruck
Feb 26, 2017 07:07 AM
raptor510
Feb 17, 2017 07:11 AM
steve miller
Oct 10, 2015 01:40 AM
