Body lift question for p/u bed
Old 10-14-2008, 04:52 PM
GenXr's Avatar
I've got a 1" BL from 4Crawler. The cab install went very well.
To install the lift on the bed, my question is this: Do I need to reuse those factory shims/pads on top of the 1" blocks to get the bed to the correct height OR only use the 1" blocks?
I couldn't find where anyone had asked a similar question.
Old 10-14-2008, 04:56 PM
TOYOTA 1's Avatar
its been along time since i have done a BL. IIRC, all those rubber pads go back where there came from!
don't quote me on it lol... I'm sure someone will chime in that knows for sure.
Old 10-14-2008, 04:58 PM
abecedarian's Avatar
well, think for a moment... ...
... if you take something out... something that was already there...
... will things line up if those parts you removed aren't there.
sorry, kinda makes me laugh-
if you add spacers all around the cab without removing anything, then you add spacers all around the bed without removing anything, if everything lined up fine to begin with.
Old 10-14-2008, 05:29 PM
Jay351's Avatar
Use the rubber spacers, they are pretty thin IIRC.
Make sure you put spacers in the middle of the bed, so it doesnt bow..
Old 10-14-2008, 05:45 PM
maybe I should rephrase-
if there are rubber spacers or whatever spacers ALREADY under the bed, install the NEW 4Crawler spacers as well keeping whatever spacers are already there... and keep the new spacers closest to the bed.
Old 10-14-2008, 07:27 PM
GenXr's Avatar
ok guys, thanks. I just wanted to double check before I put it back together. I've had bed off for a couple of weeks now so I'll have to look at the dealership print out to see which spacer go where since there are two different thicknesses.
I'll try to keep the stupid questions to a minimum.
Old 10-14-2008, 07:29 PM
Noltz's Avatar
Fair enough... but you need to put something back in there.
09-04-2015 09:27 AM
Tyler Cunningham
07-11-2015 10:18 AM
God's Bounty Hunter
07-08-2015 12:54 PM
MTLroadierunner
07-06-2015 12:17 PM
mickyd9990
07-06-2015 09:01 AM
Quick Reply: Body lift question for p/u bed
