Front Brake Upgrade
Old Oct 17, 2008 | 01:40 PM
wrxnefx06's Avatar
Front Brake Upgrade
I was wondering if there are any easy upgrades for brakes beside stainless steel brake lines and brake pads. Are there any other brake calipers that bolt up that seem to more effective at stopping. I just need more stopping power. I have a 88 4runner 22re w/ 35's. I will be downgrading to 33's here in a couple of months so that should help a little bit, but any help would be great..
Old Oct 17, 2008 | 01:45 PM
1styota4X4's Avatar
I thought that I read somewhere you can use a turbo trucks brake booster its a double diaphram. That should help. Also is you LSPV working correctly?
Old Oct 17, 2008 | 02:45 PM
jason191918's Avatar
A larger MC would help too. Search tundra brake upgrade. People use those too.
Old Oct 17, 2008 | 02:48 PM
Toyvana's Avatar
I ordered drilled/slotted rotors from Performance Products along with some HD brake pads. Really helped my 37's come to a stop.
Old Oct 17, 2008 | 03:04 PM
BigBluePile's Avatar
I think the v6 trucks have better front calipers than the 22re trucks. If you can find those in a junk yard, cheap upgrade. I'm pretty sure I've found that idea around here somewhere...
I didn't know that the turbos had dual diaphragm boosters, but I think the early supras or celicas had them too...
You really want to go all out, do a rear disc swap.
Old Oct 17, 2008 | 04:31 PM
Matt16's Avatar
Get a stronger right leg?
Old Oct 17, 2008 | 04:34 PM
ha ha
Old Oct 17, 2008 | 04:42 PM
abecedarian's Avatar
lol @ Matt16... but what about us other people that sometimes use the left leg on the brakes ('cause we can heel-toe things)?
but off the original question- there are 6 piston calipers available (I believe they were V6/turbo related, stock/base were 2 or 4 piston depending...) that will help the brakes work better, vented/slotted rotors can help, but only do so if the brakes are running hot already (like in a high-speed situation), good brake pads can help (but composites usually require high temps before they do anything noticible, so a high-speed situation is where they shine, but definitely go semi-metallic... they might eat up a rotor a bit quicker than an organic pad but also stop way better and work well with vented/slotted rotors), a master cylinder upgrade won't hurt, and for the coup-de-gras... properly adjusted rear brakes work wonders.
Old Oct 17, 2008 | 04:48 PM
Isn't that right heel on brake and right toe on gas?
Old Oct 17, 2008 | 04:54 PM
hehe
don't know about everyone else, but I heel/toe the clutch sometimes... particularly if I know I'm not going to need the clutch right soon.
maybe it's subliminal practice for lockers?
and I've been doing it for 20 years, so maybe I'm just the strange one (okay, well that's obvious, but...)
Old Oct 17, 2008 | 05:06 PM
Jay351's Avatar
Haha, never heard of heel/toe'ing the cluch and brake always been gas and brake for me (easy brakestands!)
Old Oct 17, 2008 | 05:10 PM
a4runnerfreak's Avatar
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
the mind is telling you something Abe, listen and obey. It's telling you that the truck really wants a locker
black diamond's Avatar
hehe
your kidding i hope.
Old Oct 17, 2008 | 05:12 PM
shh... I'm trying to ignore it... and pay the house bills too.
the sad thing, is it's the 91 auto I find myself using the left for brakes most often... and that's 2wd... gasp.
nope.
Old Oct 17, 2008 | 05:13 PM
never ignore the obvious, it won't ignore you.
No BD, he really is strange......
Old Oct 17, 2008 | 05:15 PM
i understand,
Old Oct 17, 2008 | 05:17 PM
Matt16's Avatar
hehe
I can't heel toe, the pedals are shape right for that. I can use my right foot to control them both at once by tilting my foot side to side.
Old Oct 17, 2008 | 05:21 PM
he was refering to the clutch/brake...
