Dash board!
Old Oct 19, 2008 | 07:12 AM
YoterUp's Avatar
Dash board!
alright ive been looking into an early 80s model yoter i went and looked at one yesterday and it had a cracked up mess of a dash board, 1st how doable and 2nd is it possable to swap a early 90s model dash to a 1st gen? i know its not going to be a bolt on job but how doable is it?
Old Oct 19, 2008 | 11:11 AM
Yodaforce's Avatar
Depends on how patient you are. Anything is "doable", but a dash replacement is a tricky one. Sounds like a good idea though. Depending on how the rest of your truck looks, I would consider making a dash from scratch. I'm planning on building my own dash (one day), with some Autometer guages and custom touches (like form and paint).
Old Oct 19, 2008 | 12:17 PM
Noltz's Avatar
Took some pictures of my 2nd Gen Dash for ya, just to get an idea;
It's 135cm wide, approximately. Click for fullsize................................................About 72cm off the floor in height. Click for fullsize
Measurement from the floor. Click!.................................................. .............. and the width of the instrument panel. Click!
Old Oct 19, 2008 | 01:57 PM
sh0kk86's Avatar
it can be done, youll need to mood the crossbar, and other things as well from what i can remember reading.
search over on pirate, i know its been done before, 3rd gen interior into a first gen p/u, taco interior into a first gen runner. i got pics somewhere, just cant find em.
Old Oct 19, 2008 | 02:00 PM
YoterUp's Avatar
thanks im still looking for posts on it if anyone else has done it otherwise if i end up going through with it ill be sure to post it thanks guys.
Old Oct 19, 2008 | 03:18 PM
Noltz's Avatar
FOUND!
Pirate; http://pirate4x4.com/forum/showthread.php?t=668813
Looks pretty straight forward. No "write up", but there was no mods to the plastic, only the cross bar underneath. So you'll need a cutoff wheel or hacksaw to trim, and a drill to do the bolt holes.
One guy even swapped the wheel to a 2nd gen. All in all, they look way better.
Old Oct 19, 2008 | 03:43 PM
YoterUp's Avatar
man that looks WAY better makor props for finding it thanks!!!
Old Oct 19, 2008 | 03:49 PM
YoterUp's Avatar
i didnt see any step by steps but still nice to see it can be done! if i get into this build that will deff be one of the 1st steps i do! does anyone know about door panels? i dont think its doable just wanted to ask
Old Oct 19, 2008 | 04:26 PM
space-junk's Avatar
idk... kinda cool idea, but its got a lot of gaps... like between the door and dash, around the steering column, and even the glove box... for me, i guess, i like a little better fit and finish...
Old Oct 19, 2008 | 04:30 PM
olharleyman's Avatar
Dang I wonder can a 2000 taco dash go into a 2 gen runner that way I can keep the original dash to my 3.4 swap and it's actual mileage of the motor.
Old Oct 19, 2008 | 06:07 PM
space-junk's Avatar
heck its only 7 years and 2 body styles different!!
Old Oct 19, 2008 | 08:16 PM
YoterUp's Avatar
anything is doable its just how much customizing you have to do. id really like to put a 06 taco dash in an 85 with the in dash GPS that would just be sick but i dont know how doable that one is! lol
Old Oct 20, 2008 | 04:51 AM
vwfastg60's Avatar
Im looking in to swapping a taco dash in my 87. I see a ton of issues but i have done a bunch of dash swaps in VW's I also know a few guys that seriously are amazing when it comes to a factory flush fit with a dash and having everything work. Most of the headache is making vents work, Heater control, cluster fitting, Wiring the new goodies.
Old Oct 20, 2008 | 02:45 PM
BlackBox's Avatar
If you don't have power windows, you may have a bit of a problem rolling the driver's window up and down. My truck's PO swapped in a 2nd gen Runner dash - apparently quite hastily - and it looks like crap. There are not only gaps (as someone mentioned) but the top of the dash doesn't line up with the windshield either.
Personally, I'd rather spend a few more $ and replace the OE dash.
Just my $.02
Old Oct 20, 2008 | 06:02 PM
YoterUp's Avatar
i dunno if i hade to repace it i think id make a diamond plate dash with custom guages but i wasnt trying to do all that i like the 3nd gen dash so i think ill atempt that especially since i got one in the barn!
kawazx636
Oct 6, 2021 03:03 PM
TheBFA
Feb 15, 2020 06:55 AM
smilen724
13
Nov 8, 2015 04:11 PM
zombie_barbarossa
Oct 2, 2015 10:54 PM
toyotasaurus
Sep 24, 2015 03:30 PM
