22r oil pump
Old Oct 22, 2008 | 03:45 PM
91 yota's Avatar
22r oil pump
i took my motor to get the machine work done today. and i was looking at the manual when i got home. i'm wondering how to prime the oil pump when i put it back together. thanks
Old Oct 22, 2008 | 04:15 PM
abecedarian's Avatar
cover the gears with vaseline or moly grease
leave the spark plugs out for the first 20 seconds of cranking.
you're going to change the oil and filter after the first 15 minutes of running so no harm.
Old Oct 22, 2008 | 04:47 PM
slacker's Avatar
yep .. as above ..
I use moly lube , or lucas instead of vasaline .. just my preferance .
Old Oct 22, 2008 | 05:06 PM
91 yota's Avatar
can ya'll get more technical on the type of grease? sorry for being kinda dumb it just looks like grease could stop up some passages or ports to me.
Old Oct 22, 2008 | 05:13 PM
most grease is soluable in oil.
once the oil comes through, the oil will wash the grease out.
technical specs of the grease? okay...
vaseline. molybdenum wheel bearing grease.
Old Oct 22, 2008 | 05:14 PM
that's why I recommended to leave the spark plugs out for the first 20 seconds of cranking... so the oil could flush the grease out... (and I don't think vaseline can rationally be described as grease)
Old Oct 22, 2008 | 07:20 PM
just a 22re's Avatar
i used brake in lube for mine
Old Oct 22, 2008 | 08:34 PM
brake in lube?
that must be an "Adam and Steve Channel- Speed Week / Deadliest Snatch" special offer.
Old Oct 22, 2008 | 08:46 PM
88T4R's Avatar
yeah so did I, its called moly lube or grease same thing!
Old Oct 23, 2008 | 07:39 AM
91 yota's Avatar
thanks guys. have any of you ever had any trouble with it picking up? i'm talking bout picking oil pressure after a rebuild.
Old Oct 23, 2008 | 07:53 AM
The_Jerbel's Avatar
Guys,
Excuse me, I'm new to the forum and to Toyotas. I recently came from the Audi world, which are a totally different game.
Isn't there a fuel pump fuse? Whenever I did engine work or turbo swaps on Audis, I'd just pull the fuel pump fuse and crank the engine for 20 seconds. No need to pull all the spark plugs...
Please correct me if I'm wrong, I'm anxious to learn the nuances of these Toyotas!
Old Oct 23, 2008 | 08:11 AM
stagger_lee's Avatar
Jerbel - All cars are different man. I would just listen to the gurus here and how they do their cars. I'm a former Audi nut too and you know as well as I do how quirky those germans are.
You grease the gears so there is some lube there before just dry cranking the motor. No sense in have the plugs there if you don't want it to fire, and if you don't have spark there anyway, you don't want risk gunking up your new plugs if some grease makes it way around that way. Also keeping the plugs out won't create compression allowing to the oil flow up more freely, maybe? I am in no way a guru, but that was the sense I made of this method. Cheers!
Old Oct 23, 2008 | 10:24 AM
The_Jerbel's Avatar
Stagger,
Thanks for your reply, all cars are definitely different with very different systems. That's why I asked.
I'm just saying that if the plugs are already in the cylinder head, it's just extra work to remove them, and if you WANT to, then by all means, there's nothing wrong with that.
Grease can't make it into the cylinder to gunk up the plugs. The piston rings seal the oil on the outside of the piston (between the piston and cylinder walls). Oil should get splashed up to the piston regardless of the compression.
I don't think those are the reasons why they pull the plugs, but I would like to know why they do it.
Old Oct 23, 2008 | 02:08 PM
the point to pulling the spark plugs is to relieve compression while the engine is turning so that the engine turns faster than normal during cranking, thus getting the system primed and oil up through the bearings, etc as quickly as possible...
... and as a side benefit, zero chance of the engine starting.
Old Oct 23, 2008 | 03:03 PM
91Toyota's Avatar
Basically when I rebuilt my engine I could NOT turn over my engine by hand. It was so hard. I had to use a breaker bar with a cheater bar and it was hard as h3ll. I primed mine by turning it over by hand with oil for a long time...probably about 30 minutes and it hurt my back. lol
Old Oct 24, 2008 | 01:19 AM
ovrrdrive's Avatar
In a fresh motor the break in lube lubricates the top and bottom end and in a motor that was running before the work there's already oil in those places so I've never been worried about lubrication in those first fractions of a second. Just pack the gears with Vaseline and be done with it. Vaseline becomes soluble at a lower temp than grease does so there's less chance of a passage becoming blocked for any length of time and it's harmless to the engine.
You're going to do a quick oil change anytime you crack open the engine anyway right?
It's always a good idea because of all the trash that falls in accidentally.
bigjstang
Jun 2, 2025 03:56 PM
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
cars-guy
Jul 11, 2015 07:51 PM
87blyota
Jul 10, 2015 04:31 AM
