help weird noise from front pass. tire
Old Oct 20, 2008 | 06:05 PM
fireman1559's Avatar
here lately i here this weird noise coming from my front pass.tire its the hub its like a grinding noise its not loud but its annoying like when i have my windows down and pass a car or truck or whatever i can hear it i have searched for it on here and cant find it it is coming from the boot bhiend the tire i can turn the front drive shaft to that tire and i can hear it and it turns really easily but the drive side drive shaft wont turn that easy and it doesnt make any noise can anyone help me?
Old Oct 20, 2008 | 07:57 PM
desert-rat660's Avatar
maybe thr brake pads are metal to metal on the right front
Old Oct 20, 2008 | 08:02 PM
nope replaced those and i have new rotors
Old Oct 20, 2008 | 08:05 PM
a4runnerfreak's Avatar
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
Cv maybe?
Old Oct 20, 2008 | 08:07 PM
bearings shot? does the wheel have play if u take the load off of it?
Old Oct 20, 2008 | 08:14 PM
yea its easy to turn compared to the drive side and when u turn it it has a grinding noise
Old Oct 20, 2008 | 08:22 PM
There's an easy way to check your wheel bearings. Jack up your front end, support it on jacks. Grab the wheel at the 9 and 3 o'clock positions, and wiggle back and forth. There shouldn't be any excessive play (if at all). Then place a small block of something under the tire, and using a long prybar or something similiar, lift the tire up. It shouldn't move at all. If there is play, replace the bearings.
Old Oct 20, 2008 | 08:33 PM
thanks ill try that tommmrrow anything i should try or i can do to see what my problem might be
Old Oct 20, 2008 | 08:40 PM
Try that. If all is well with your bearings, look at your cv joints. Look to see if the boots are ripped/torn/ etc. Do you locking hubs, or the ADD system?
Old Oct 20, 2008 | 08:43 PM
just a 22re's Avatar
i bet you money and beer its your wheel bearings wanna know how i know cause mine does the same thing sounds like a pissed off dog under the hood when ever my front hubs are locks im guessing you have add so your stuck there and yes its the bearings cause mine are shot!!!
Old Oct 20, 2008 | 08:46 PM
.01 counts right? thats money
Old Oct 20, 2008 | 08:48 PM
Shut up, Norbert. Hey, your trailer park called, the trash is missing again.....
Old Oct 20, 2008 | 08:59 PM
all the boots are fine nothing is torn and yess i have add system so im going to have to go with wheel bearings ill replace thos and let yall kno thanks
Old Oct 20, 2008 | 09:03 PM
tonnnnnnnnny are you feeling ok or just ggggrrrreeeaaaattttttt?
Old Oct 20, 2008 | 09:14 PM
Yeah, check the bearings 1st, fireman, then post back let us know.....
And I'm feeling fine Norbert....lol
Old Oct 20, 2008 | 10:05 PM
Jay351's Avatar
Who did your rotors? They mustve screwed up the wheel bearing install..
Old Oct 21, 2008 | 03:56 AM
i replaced the rotors i replaced them because i heard the noise and at first i thought it was only when i was stoping but hte more i listend it was always there
Old Oct 21, 2008 | 11:48 AM
i checked that tire how yall said too and there was no play it was solid now what do i need to do should i go ahead and replace both my wheel bearings up front? or could it be something else another guy on here put up a video of him turing his front cv and it made the same nois mine is making does that mean i need to rebuild the hub on that side?
Old Oct 21, 2008 | 11:58 AM
ok i just went out and checked when i put it in to 4wheel drive the passenger tire does not engage its still loose i checked both and the drivers side was locked i couldnt turn it with my hand so i guess that means my hub isnt engaging and i need to have it rebuilt??
Old Oct 21, 2008 | 02:08 PM
Jay351's Avatar
Spin the tire (truck off) in the air with the hub unlocked, does the CV joint move? Turn the wheel with the hub locked, does the cv joint turn too?
You have an open diff so one tire will spin free..
