idle problem?
Old Oct 19, 2008 | 09:51 AM
yoder519's Avatar
idle problem?
i got a 95 p/u 22re and i noticed the other day when i pushed the clutsh in to change gearas and it revved it slef up. so i thought maybe i just didnt let out of teh gas in time. then when i get to the stop sign i pushed the clutch in and my truck reved up. it wasnt constant just sounded like i was pushing the gas then lettin off, but i wasnt. and now it does it bout once everyday then stops. so is theresomethin wrong with my idle? i figure somethin mighta came loose or somethin. thank ye
Old Oct 19, 2008 | 10:17 AM
abecedarian's Avatar
does it do it if say, you're idling in the driveway then just depress the clutch? or is it more like only when you're driving?
Old Oct 19, 2008 | 06:20 PM
desert-rat660's Avatar
will it do it in neutral
Old Oct 20, 2008 | 09:36 AM
yoder519's Avatar
most of the time when i go to start it up in the mornin, then aftrer i drive it lets ssay, 5 miles itll start doin it. and yes it does it neutral. and if im just in 2nd gear going thru a parkin lot itll give itself gas and pull w/o touchin the gas pedal
Old Oct 20, 2008 | 10:06 AM
check for a vacuum leak, also maybe u just have the idle set too high
Old Oct 20, 2008 | 10:10 AM
coryc85's Avatar
Sounds like a vac leak and the ECU is compensating by raising the idle. You can put a vac gauge on it or you can spray some starter fluid to try and find it. If this is a sudden change, you might just look around and see a hose that came off.
yoder519's Avatar
i havnt touched the idle any. never thought of a vacum leak thank ye. a guy that knows his stuff said it could be teh auotmatic choke kicking in when it shouldnt be or somethin
Old Oct 20, 2008 | 10:14 AM
coryc85's Avatar
Choke is for carb'd engines. You have the fuel injected 22re. When you first start it up, the engine is cold and the idle is high, after driving for a little bit, the engine warms up and you drop to normal idle, that is when you will see the problem with the vac leak.
Old Oct 20, 2008 | 10:33 AM
use carb cleaner to check for the vacuum leak, or listen for a hissing sound around the intake manifold. if u dont find anything it could be the ac idle up valve.
Charecter1
Nov 6, 2023 10:08 AM
Eggslinger
Jun 8, 2019 03:32 PM
Alex Bessinger
Aug 31, 2015 09:17 AM
kyletbert
Jul 17, 2015 11:39 AM
Jnkml
Jul 6, 2015 01:20 PM
