Timing Chain
Old Oct 14, 2008 | 06:16 PM
my-4x4's Avatar
Exclamation Timing Chain
You guys here are definatly ALOT of help, so would you tech's like to break down the process in general of replacing my timing chain? How long am I looking to spend (being a noobie and a first timer)?
87 22r 112k miles
Old Oct 14, 2008 | 06:24 PM
DeathCougar's Avatar
2 hours?
You'll never know until you do it.
Its like me asking "how long will it take to make a batch of cheese? I have no idea until I do it, as everyones times vary!
Old Oct 14, 2008 | 06:36 PM
rdlsz24's Avatar
To get started download the FSM from a link you can find on here and study the timing chain section. I think I almost had the headgasket section memorized by the time I started work on mine.
Rob
Old Oct 14, 2008 | 08:35 PM
just a 22re's Avatar
drain coolant drain oil, remove rad, fan belts, remove valve cover 4 12mm, remove crank pulley, remove timing cover theres one sick bolt under the oil puddle way up in front of the head, clean up everything, unbolt the oil pressure chain tighter, take screw driver in hole on cam unbolt cam gear, remove chain gides, remove crank gear, then do the same backwards and you should be done
i think that about summs it up for ya hope it helps you out some
Old Oct 19, 2008 | 10:57 AM
my-4x4's Avatar
thanks alot everybody
Old Oct 19, 2008 | 11:14 AM
RiNkY's Avatar
Tempted to give it a shot myself - never done much more than suspension / brakes before and regular maintenance, but I think I can tackle this one with the amount of information available.
Old Oct 19, 2008 | 11:39 AM
88wildrunner's Avatar
im gona be looking to replace mine this winter too. the question that i want to know about changing timing chains is. do you have to pull the head off to replace the chain or is pulling the oil all you need to do. because i really dont want to have to deal with the head.
Old Oct 19, 2008 | 12:00 PM
abecedarian's Avatar
it can be done without removing the head. you have to be careful of the portion of the headgasket between the head and the timing chain cover. so no prying in that area.
Old Oct 19, 2008 | 12:11 PM
84YotaBuck's Avatar
No, you don't have to remove the head. I spent a weekend doing mine, looks kinda like this with the head still on and timing chain cover removed.
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
razorman8669
Jul 12, 2015 12:13 PM
