removing spare tire from rig
Old Oct 15, 2008 | 10:19 AM
keithguts's Avatar
Today I was trying to remove my spare tire from under my rig, and no luck. It is all rusted and the thing will not turn. Any help in this matter would be great.
No, I don't have a flat thank god, or I be stuck. Just wanted to take it down to lube things up. I guess it's to late for that. Anyway, any help on this?
Old Oct 15, 2008 | 10:21 AM
just a 22re's Avatar
try the spin and kick
thats where ou kick the tire and try to turn the lowing thingy
Old Oct 15, 2008 | 10:23 AM
tc's Avatar
tc
Let the air out of the tire, then use a jack to squish it up under the bed. You can usually get enough slack to work the holder loose and drop the tire.
Or you can cut the chain/cable.
Old Oct 15, 2008 | 10:26 AM
91Toyota's Avatar
You might just have to cut it off...lol. I would try beating on it first...then mount it...not like me
Old Oct 15, 2008 | 10:32 AM
keithguts's Avatar
I did a searsh, and PB seems to be the best way to try to get it loose. My question is, should I spray it for a few days and then try, or just spray it, beat it, and hope for the best?
Old Oct 15, 2008 | 10:38 AM
91Toyota's Avatar
I would spray it and wait like 10 minutes then beat it...if it doesn't come off like that keep spraying it for a couple of days.
Old Oct 15, 2008 | 10:39 AM
tc's Avatar
tc
You can try PB, but you live in a salty part of the country - that thing is rusted SOLID. There's a little gearbox over to the driver's side that is right in the way of the spray coming off the rear tire. It's DONE.
Get to cutting.
If you want a new hoist, let me know. I have one that was bought by a previous owner about 5 yrs ago, it's a chain style instead of the cable style, but works great.
Old Oct 15, 2008 | 10:41 AM
keithguts's Avatar
I think when I do get it down, it is going to go up in my rack, this way I don't have to worry about getting it down ever again. Any draw backs of being in my roof rack?
Matt16's Avatar
Edit: Wondering how many will get it.
Old Oct 15, 2008 | 11:05 AM
Jay351's Avatar
I beat on mine after I soaked it in PB blaster.. Nothing doing! Ended up torching it out.
Old Oct 15, 2008 | 02:22 PM
tc's Avatar
tc
Other than raising your already too high center of gravity?
Old Oct 15, 2008 | 03:11 PM
Noltz's Avatar
I cut mine out. The cable actually broke on the PO and he lost his spare on a highway somewhere... Now run with a plug kit and my OBA.
Old Oct 18, 2008 | 02:23 AM
annoyingrob's Avatar
I hope nobody minds the thread jack, but I have a slightly different problem with my spare tire carrier.
It spins freely despite being quite rusted. Except, the chain doesn't move at all. No matter how much I spin it, the chain is locked in place. Anyone have an idea of what's wrong? I'm half tempted to ratchet strap the tire under the truck.
Old Oct 18, 2008 | 05:46 AM
highway's Avatar
I ended up cutting mine off then i made a mount by drilling a hole in the same spot the original mount was. drilled the hole in the center and put a piece of threaded rod and a locknut on top and then fastened the tire using a small square piece of sheet metal and nylon locknut.
Old Oct 18, 2008 | 01:02 PM
Matt16's Avatar
Sounds like the chain is jammed. I'd rope the tire to the ground and gently pull (barely any force), that might loosen it.
Old Oct 18, 2008 | 01:18 PM
Scooby098's Avatar
I have a Old dirtbike just like that....
Old Oct 18, 2008 | 02:05 PM
wardriver's Avatar
I thought mine was toast too...it was fairly close. Turns out my trouble was in the gear box...maybe yours is too. There is a pin after the gear box - remove the pin then remove the bolts holding the gear box onto the frame. Then try and turn the rod to lower the tire. Then remove the cover on the gear box and hit with PB Blaster - let it sit then do it once again for several days. Mine freed up after that - then coat with lots of grease.
Old Oct 18, 2008 | 02:06 PM
wardriver's Avatar
And you'll increase drag thereby reducing your mpg.
Old Oct 18, 2008 | 03:31 PM
jason191918's Avatar
I had to cut mine off, then get one from collier (dirttoyboy).
Old Oct 18, 2008 | 05:25 PM
GenXr's Avatar
You are funny! That was hilarious.
mine rusted and had to be cut off too. So now the spare travels in the bed until I find a different mount for it.
Sep 4, 2015 09:27 AM
DrZero
18
Jul 24, 2015 11:31 PM
Nailit69
Diesel Swaps
Jul 21, 2015 05:28 PM
DrZero
Jul 13, 2015 09:59 AM
skoti89
Jul 8, 2015 12:05 AM
