low, ruff Idle at warm start up
Old Oct 14, 2008 | 10:42 PM
johnnyboy's Avatar
Exclamation low, ruff Idle at warm start up
I have a 92 22-re that starts up just fine when it is cold but when the motor is warm and i start the truck it idles ruff and sounds like is struggling to get up to rmp's. I thought mabey the cold start was stuck on open loop, also thought that the fuel pump wasnt working quick enough. If any one has an idea about possible check list that would be helpful!
Old Oct 14, 2008 | 11:02 PM
abecedarian's Avatar
tune the engine warm- like the factory intended.
and cold start on any engine is open loop... most warm start is open loop too
Old Oct 15, 2008 | 06:48 AM
Pistonman's Avatar
Leaking Injectors can cause this also.
Old Oct 15, 2008 | 11:15 AM
johnnyboy's Avatar
Yeah i thought it would be a bad injector, also i know that my coolent gague is all the way cold im going to put in a different theromostat so that the engine runs hotter, I read some other forums that said temperature has alot to do with fuel mixture. And some times it acts like it loses fuel pressure when i turn the motor off and then restart the motor the gas gauge goes down, I have tuned the motor several times with it warm and it still has the same problem. When i bought the truck the dealer said it had a bad cold start injector but i tested it and it was ok on the amount of ohms but it still could be leaking......you think?????
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
slider417
Jun 22, 2015 10:18 AM
Fred Anarat
12
Aug 27, 2002 04:50 PM
RgrChu
Jul 13, 2002 08:53 AM
Skydigger
Jul 1, 2002 12:39 PM
