Adding Tilt?
Old Oct 20, 2008 | 02:39 PM
jlschrrs's Avatar
Adding Tilt?
I was looking at a 94' runner today to purchase for myself...very interested but it doesn't have tilt and I can't fit my 6'8" self in without having the steering wheel in my lap. What would it take to switch the tilt column from my '90 runner? Is this at all possible?
Old Oct 20, 2008 | 02:43 PM
just a 22re's Avatar
not so sure on the newer runners but if it fits then its just a bolt on 2 bolts under the dash and a bolt on the turning thingy by the pedels not hard just make sure you have everything lined up or the steering wheel might be off set
Old Oct 20, 2008 | 02:52 PM
one2high's Avatar
Yes, it is a direct bolt-in. The wiring is the same and the switch is easy to swap.
Old Oct 20, 2008 | 02:54 PM
NicCantDecide's Avatar
its entirely mechanical, its just a compression lever that holds it tightly in place. All you need is the mount with the lever off a junked truck.
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
irv
Oct 1, 2015 09:49 PM
bradahman
Oct 1, 2015 09:24 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
longbed
Sep 16, 2015 10:35 AM
