Quick TPS adjustment question
Old Oct 16, 2008 | 05:57 PM
91Toyota's Avatar
22re. Adjusting TPS. How far should I turn the screw in on the throttle plate? (to where the butterfly opens) don't tell me how far or how many turns...because I have a different bigger screw (wouldn't hold the small original one...so I replaced it) Thanks!
Old Oct 16, 2008 | 05:58 PM
abecedarian's Avatar
you should not adjust the throttle plate at all
unless you have a bench flow meter to calibrate the throttle against.
so, go back to fixing your engine.
Old Oct 16, 2008 | 06:04 PM
91Toyota's Avatar
Thats been too late...its supposed to be at 6 degrees per manual...I'm guessing it doesn't matter then...lol.
But the point is the screw fell out. Put a new one in...I don't want the throttle to stick
Okay I'll leave now
Old Oct 16, 2008 | 06:24 PM
so, you've adjusted the throttle stop, whether inadvertantly or not?
out of concern... how many turns on the screw equals 6 degrees?
Old Oct 16, 2008 | 06:25 PM
too many turns on the screw= too high idle.
Gone Fission
Jan 12, 2023 10:34 AM
jasonty
41
Dec 23, 2018 01:00 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
yourrealdad
Jul 21, 2015 11:13 AM
icentropy
Jul 14, 2015 10:23 AM
