Moog ball joint ???
Old May 8, 2012 | 04:57 PM
T_BONE's Avatar
Moog ball joint ???
Just got my Moog ball joints in to replace both upper and lower on my 92. I am having a real hard time getting the boot to seat onto the base of the ball joint. It has a hardened ring encased in rubber and the fit is crazy tight. I have tried to force it on by hand and resulted in a small tear at the seam of the ring and the boot. This is only a problem with the upper joints. Anyone out there in Yotatech land know what I am talking about?? Comments and suggestions welcome.
As always thanks,
T_BONE
Old May 8, 2012 | 05:00 PM
rworegon's Avatar
Did you try putting a bit of grease on the boot/lip where it seats? Can you use a tiny pocket screwdriver under the boot to help ease it down?
Old May 9, 2012 | 09:22 PM
T_BONE's Avatar
found this!!
This was helpful for the second one I installed.Maybe this will helpsomeone else with the install. Socket worked perfectly. http://www.moogproblemsolver.com/_pd...K11_102_En.pdfRockauto is replacing the one with the torn boot. Gotta love that.
T_BONE
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
4x4YOTA
Aug 23, 2016 09:08 AM
crash813
Sep 27, 2015 07:15 AM
Odin
Sep 26, 2015 06:56 PM
