86 22re in a 93 body
Old May 15, 2012 | 12:38 PM
chrismhartley's Avatar
had an engine go and found a cheap engine with 65xxx on it only it was a first gen. pulled out and went in except the wiring. The wiring is completely different. If i buy i 86 wiring harness and 86 ECU will it simply plug up and run??? please help 5088013924
Old May 15, 2012 | 02:51 PM
would i be better off ripping it down to the block and using the 93 intake manifold and splicing the rest???
Old May 18, 2012 | 10:34 AM
ok so just got everything installed and engine runs when im spraying starter fluid into the intake manifold but then it just dies??? fuel pump is good and fuel filter is good
montanatruck
Feb 26, 2017 07:07 AM
coleypull15
Nov 3, 2015 07:41 AM
Sep 4, 2015 09:27 AM
Michael oaks
Jul 27, 2015 11:47 AM
Backcountry411
Jul 24, 2015 08:06 AM
