Too much slip yoke play? (Video)
I have been chasing down a vibration in my driveline that occurs at 65mph + under no load, or whenever I let off the gas. The rest of my double cardon drive shaft has no play except for the slip yoke as seen in this vid:
http://s1097.photobucket.com/albums/...ipyokeplay.mp4
Is this excessive?
Is this excessive?
Might be, usually vibes while coasting are due to something being loose. Some quick tests listed below:
- http://www.4crawler.com/4x4/CheapTri...FixingProblems
Thanks for the responses. This particular slip yoke came with the 5.29'd gear I bought locally off of a 4cyl. My original slip yoke from my stock V6 would not bolt up so I am using the one 4cyl version. I figured the experts on this forum would have a pretty good idea if that is excess play or if that is fairly common.
I actually did remove the yoke and greased it up (alot) despite its appearance in the vid. At the same time I lined the u-joints up to ensure the joints were in phase as best I could. The vibration wasn't as bad after this so I am pretty sure its the yoke. Prior to this, I did as 4crawler suggested, removed d/s, tightened the pinion nuts and restaked, checked each u joint and the carrier bearing. So I have narrowed it down to either too much pinion shim (6 degrees) or the slip yoke. Or a combination of the two.
I can get my original slip yoke back on by either using the flange from my stock differential or a triple drilled flange option. It will be a few days before I have access to my junk pile though.
ashamsuddin
17
01-13-2023 03:17 AM
LittleUgly
15
01-02-2020 01:30 PM
hiluxinargentina
09-30-2015 11:12 PM
hiluxinargentina
09-30-2015 05:51 PM
