Wrong Lower Control Arm Bushings?
Old May 6, 2012 | 10:11 AM
Ditch Doc's Avatar
Hey all!
Okay, so I have to torch off my camber adjustment bolts and replace them. Gonna replace the lower control arm bushings while I'm in there. I ordered a set from Advance Auto Parts because they were a lot less expensive than Yota.
They came in the other day. Each bushing was in its own box. Two bushings were smaller than the other two, and seem to be a different design, but the numbers on the boxes were all the same. (two of the boxes were also smaller than the other two).
I called Yota. They are showing all of the bushings as the same part number. Does anyone know which one of these is right?
Thanks!
Doc
Old May 6, 2012 | 11:36 AM
wii_tarded's Avatar
The one on the left is the correct bushing. If you don't mind the noise, Energy Suspension sells bushings for 4 control arms for fairly inexpensive. I replaced mine, they creak a little when moving, but should last quite a long time. Only issue with them is you have to re-use the core sleeve which can be a pain to remove.
Edit: the other one looks like it could belong to the upper control arm.
Old May 7, 2012 | 08:15 AM
GDR's Avatar
GDR
The one on the right looks like a 2WD LCA bushing.
88sasturbotoy
Jan 30, 2026 01:57 PM
kirkrunner
Jul 27, 2015 07:59 PM
KyleT
Jul 21, 2015 07:54 PM
ksmudrunner99
Jul 21, 2015 05:33 AM
1994toyota
Jul 17, 2015 03:03 AM
