3VZE - Need help identifying connector
Old May 18, 2012 | 11:12 AM
adamthedroog's Avatar
A while ago I noticed this stray connector behind my battery. I looked everywhere for a place where it should go but couldn't find anything.
This is the connector:
It goes through here
And through side next to the battery
Old May 18, 2012 | 11:28 AM
MudHippy's Avatar
A.D.D. Indicator Switch...maybe?
Old May 18, 2012 | 01:03 PM
vital22re's Avatar
totally a bro
a.d.d is on the driver side. Is your washer fluid pump working?
Old May 18, 2012 | 01:15 PM
Yes it is.
Old May 18, 2012 | 01:29 PM
vital22re's Avatar
totally a bro
Maybe a pressure switch for the a/c? all the vsv's are further back on the fender.
Old May 18, 2012 | 01:43 PM
vasinvictor's Avatar
http://screencast.com/t/jnwUBjrwH0ry
Old May 18, 2012 | 01:45 PM
Originally Posted by vasinvictor
No I was working on something else that's unrelated.
Old May 18, 2012 | 04:25 PM
Punchy's Avatar
Thats ether the AC pump connector or the Antilock brake connector (Look straight down from the powerstreering pully and you will see a unit mounted to the frame with PS and brake lines going to it.
Old May 18, 2012 | 05:21 PM
It's not the antilock brake connector so where's the AC pump.
Old May 18, 2012 | 05:27 PM
bmcghie's Avatar
The AC fan and condenser units are in front of the rad. I just removed mine the other day and got rid of the wiring harness. It might be power for the AC fan. Have a peek under the passenger fender, beside the vacuum tank. You might be able to see where it goes.
Any issues with how the truck runs?
Old May 18, 2012 | 05:59 PM
Yes actually the idles all screwed up. It almost stalled today.
It probably isn't the AC fan cause it starts up when I first start up the truck.
Old May 18, 2012 | 06:53 PM
bobbybouche's Avatar
I have that plug hanging in my 94 4runner 22re also, no home for it.
Old May 18, 2012 | 06:56 PM
I looked behind my fender and it goes towards the back of my truck. It might have to do with A.D.D. but I looked at all of the components and they have connectors already.
Old May 18, 2012 | 09:14 PM
nathanmyers's Avatar
either the AC or egr valve but it looks like you have the egr valve plugged in. I don't think it is long enough or it is it but I think there is also another plug like that that plugs into the 4wd actuator on the front diff.
Old May 19, 2012 | 01:47 AM
BMcEL's Avatar
MadMax48
Mar 3, 2020 10:33 AM
Kamaloha
Oct 16, 2015 05:13 PM
alexcarey
Oct 14, 2015 06:05 PM
Matthew Perez
Sep 28, 2015 05:43 PM
