Air conditioner
Old May 13, 2012 | 03:14 PM
milkywaY's Avatar
Exclamation Air conditioner
Hi, Curious if ac unit from 84 pickup w/ 22r will fit my 89 w/ 22re? Please somebody...anybody. Thanks for your time. Paul
Old May 13, 2012 | 03:29 PM
Discombobulated's Avatar
After my recent ac add on on my 91 I have found out that there are many brackets fitting angles plugs etc etc that are different the only way would be to match them and try, but from an 84 to 89 I'm gonna say good luck. Even if some of it works I went through 5 compressors from the yard and they were all worn and needed a clutch ended up buying a new compressor. And these compressors were out of 88 to 90's. Get ready for a can of worms.
Old Aug 6, 2012 | 08:03 PM
ediaz82's Avatar
i have a question probably dumb to u but im new at this. my ac doesnt work when iturn it on the compressor doesnt click like other cars ive heard. the lines have no pressure so their empty where can i start the trouble shooting i want some ac its hot out there
btw when i turn it on it does blow air into the cab (not cold obviously)
Old Aug 7, 2012 | 05:02 AM
sbagdon's Avatar
Guess my first suggestion would be to replace every o-ring in the system, then vacuum the system and see if it holds that vacuum.
Old Aug 7, 2012 | 07:27 AM
ediaz82's Avatar
I read if the lines are empty or low on pressure the compressor would not kick on is tht right? So im gonna try and jump it if i can get it to click on ill feel better. Would u have any idea wht a shop would Charge to convert from r12 to r134?
Old Aug 7, 2012 | 08:29 AM
sbagdon's Avatar
Testing the a/c clutch shouldn't be an issue, as long as the engine isn't running. Turning the compressor with no refrigerant wouldn't be good for the compressor.
Don't know what your local rates are, yet problem less then $200. Yet that doesn't include fixing the leak in the first place.
Old Aug 7, 2012 | 11:02 AM
ediaz82's Avatar
thanx yea i guess its around $225
Old Aug 7, 2012 | 01:00 PM
CBECK's Avatar
Dont run it without the freon, i beleve in a liquid state it lubricates the compressor. mine got impaled by a tree branch and i ripped the whole system out and replaced the condenser with radiator armor, but its alot hotter on ur side of the mountains,the ac out of the 84 maybe has simalar cooling coils & condenser, but the aluminum hard lines are probably different and are unforgiving for sure-if you paying bottom dollar try it, otherwise find the 89 3rd gen ac and save. this past weekend got you thinkin AC it was stupid hot, good luck!
Old Aug 8, 2012 | 03:51 PM
TFOUR's Avatar
What actually lubricates the compressor is oil, not refrigerant. The reason your a/c won't kick on is because of the low pressure switched being tripped. If you try to bypass it and compress air it will break. Also you cannot just add refrigerant the system must be put on a vacuum. I would recommend replacing the metering device, also if it just leaked out refrigerant you have to find a leak very hard to do unless you have access to the right equipment. After all that theres no guarantee that your compressor will last. It also needs to be charged properly and made sure the right amount of oil is in it.
Old Aug 8, 2012 | 07:39 PM
abecedarian's Avatar
@ the OP: It would fit were it not for the fact the pickup changed bodies for the '89 model year and had a redesign of the dashboard, vents and such.
Old Aug 8, 2012 | 08:28 PM
ediaz82's Avatar
Im gonna have a shop do the vacuuming and check for leaks also drain the system i think i might be able to take care of the converting there shouldnt be any moisture getting in from the shop to my house unless there is a leak
sanctfy
Sep 13, 2015 06:33 PM
Rickstwowheels
Sep 9, 2015 06:12 PM
old87yota
Sep 9, 2015 12:39 PM
EatChipsNow
Sep 9, 2015 01:25 AM
--Oz--
Sep 6, 2015 01:06 AM
