Trailer wiring?
Old May 19, 2012 | 01:01 PM
The_Jerbel's Avatar
Trailer wiring?
Guys,
This is a '90 Runner with 3.0L, 4x4, and the towing package. I've tested output at the 4-pin trailer connector, and when the brakes are applied, I get 12 volts to the right trailer light, but only 6 volts to the left. This is being measured right at the 4-pin connector coming off of the truck. Any ideas what's going on? Why only 6 volts to the left light?
When did they start using those modules that I've been reading about that converge 5 signals from the truck into 4 signals to go into the 4-pin trailer connector, and which tend to fail?
Thanks for any tips or pointers.
Jordan
Old May 19, 2012 | 01:12 PM
wyoming9's Avatar
Wink
That is interesting have you checked at your brake light pin on the tail light.
I would bet is that stupid box.
I never used a 4 pin flat plug I always wire my own 6 pin plugs.
Old May 19, 2012 | 10:04 PM
The_Jerbel's Avatar
I haven't checked the voltage at the brake light yet, just at the trailer connector. If the box is cooked, is there an upgrade mod for this, so I don't have to replace it with another error-prone OEM module?
I actually have a 7-pin plug that I wired into my trailer, but the connector coming out of the truck was a 4-pin. Should I just yank the module altogether and take the 5 wires directly back to my 7-pin connector?
Old May 20, 2012 | 01:20 AM
wyoming9's Avatar
Wink
I have seen other converter boxes around can`t really say if they are better or worse.
If you decide to wire direct to your 7 pin plug (forgive my typo 6pin plug)
Take your time solder and heat shrink with water proof heat shrink.
Other wise it will be a big mess I fix so many poor connections with people having trailer light issues .
Only you can decide which way will work for you.
In any case good luck
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
58rennur4
Aug 4, 2015 08:49 AM
defrag4
Jul 31, 2015 10:50 AM
shadowbirdie
Jul 21, 2015 10:38 PM
toyota32
Jul 6, 2015 05:42 PM
