4wd indicator wire hook up
Old May 21, 2010 | 02:04 PM
se7enine's Avatar
Question 4wd indicator wire hook up
So the housing off my 4wd indicator plug is broke (the one coming out of the T-case) and I'm not sure which wires hookup to the other half of the plug. Both wires from the T-case are black and the others are colored. I tried to guess and both tripped the relay but neither illuminated the indicator. The bulb is not burned out, I checked that already. Does anybody know which wire connects to each other or if it even matters? These are the wires I'm talking about.
Old May 21, 2010 | 03:28 PM
eric-the-red's Avatar
It doesn't matter on the transfer case. The switch won't care which way the electrons flow through it.
Old May 21, 2010 | 04:04 PM
se7enine's Avatar
That's good to know, I didn't want to burn any fuses trying to find out which connection worked. Thanks eric
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
adammtb
Jul 27, 2015 11:57 AM
shisha1999
Jul 13, 2015 11:09 PM
Steven.m.paulk
Jul 13, 2015 01:40 PM
88yodabasket
Jul 13, 2015 01:32 PM
