Tach Help
Old May 18, 2010 | 03:44 PM
palmer_df0130's Avatar
Tach Help
Hey guy's! I recently put a SR5 instrument panel in my truck and everything works fine. The question I have is the RPM's. Can somebody that has a tach let me know how many RPM's I should be running in 1st at 15 mph, 2nd - 25, 3rd - 35, etc. My tach only reads about 1700 rpms in 5th going 55 mph, and does not go above 2000(unless I try) while normally shifting through gears. At idle, it sits at 750 like it should. It just strikes me as odd that the RPM's are not higher when going down the road and shifting through the gears. My truck is a 22re, 5-speed,W56 tranny with 30x9.50 tires. Thanks for the help in advance.
Old May 20, 2010 | 12:20 PM
yayfortrees's Avatar
Will the tach go to 3 or 4K? The 1,700 RPMs at 55 MPH in OD sounds about right.
If the tach shows a full range of RPMs, then it apparently is working correctly. From the sounds of it, I would shift a little bit later, and see if that cures your 'problem'.
Old May 20, 2010 | 01:42 PM
Thanks for the reply. If I rev the engine when not in gear, it will get up to 3k-4k, but it is screaming. I'm not sure if that's the way these 22re are supposed to sound when the rpm's get above 3k or not? I can pull to around 2300-2400 in 3rd gear up to 45mph. Are these engines pretty good at handling high rpm's? I guess I have really never got on the gas before and not having a tach prior to this, it is all new to me. I guess everything is good from what you are saying. I appreciate your help.
Old May 20, 2010 | 01:47 PM
4Crawler's Avatar
RPM on my '85/22RE is around 2800-3000 @ 65 in 5th gear, sounds like you might have a V6 cluster/tach in there:
- http://www.mindspring.com/~jayk3/toyota/tachmod.htm
You can calculate what RPM should be in a given gear:
- http://www.4crawler.com/4x4/4LoCalc.shtml#FindRPM
Old May 20, 2010 | 04:06 PM
JAvendan's Avatar
yeah... i think i'm doing 3k rpm at 70mph in 5th with approx. 31" tires and stock gearing.
edit: 22re 5-speed
joel
Old May 21, 2010 | 12:02 PM
What's the easiest way to adjust? I searched for a thread and found one on ToyotaNation that shows how to do it. Is it really as easy as rogerman says who posted the thread? My idle sounds like where it should be and reads 750rpm on the tach, but if it is a tach for a 6 cyl., does that mean I am actually idling at 1500rpms +/- 200rpms? It mentions removing the speedometer to access the screw to adjust the tach and plug the instrument panel back in, but will it mess anything up running it without the speedometer installed?
Old May 21, 2010 | 12:04 PM
I guess I should have looked at your links first, 4Crawler, before replying. I will read up on it. Thanks for the info.
Old May 21, 2010 | 12:23 PM
Good info gents!! I need to find an extra tach that I can use to get this straightened out. I am going to adjust it as in the first link above and what I mentioned about the TN thread. Thanks again gentleman and I will let you know how everything turns out.
shisha1999
Mar 3, 2016 07:09 PM
Jdgarrison
Oct 1, 2015 05:22 PM
Jdgarrison
Oct 1, 2015 02:11 PM
imhousing
Sep 10, 2015 02:04 PM
O Holy P
Aug 18, 2015 02:33 PM
