89 22RE timing cover/water pump/ mess-o-trouble
Old 05-12-2010, 04:52 PM
Brainlessmoth's Avatar
ok, so, one year ago i re-built my 22RE, didnt do anything special to it after the rebuild. a few days ago, i started having white exhaust smoke, gurgling radiator, over-heating, then the big one: more oil in my radiator than coolant. so, new head gasket, one days work...right?.....warped head needs a decking....two days right? well, its turning to three. just ripped apart my timing cover to put in a new chain guide, and have discovered that there's a long, deep section on the side of the cover that is warn and leaking...leaking pretty bad.
i'm either going to weld the leak shut, or get a new cover.........i'm going with weld because its cheeper by about 150 bucks.....JB weld? pretty sure the chain's not rubbing, and once i get the chain guide back on it wone be doing that anymore...right?
Old 05-12-2010, 05:02 PM
pruney81's Avatar
If it was me I would definitely get a new cover, one can be found here fro pretty cheap:
http://www.engnbldr.com/
mskalmus
05-28-2017 07:51 AM
steve miller
10-10-2015 01:40 AM
Nickdigg
07-07-2015 06:04 AM
bryan34w
07-06-2015 05:53 PM
Quick Reply: 89 22RE timing cover/water pump/ mess-o-trouble
