No Speedo?
Old May 6, 2010 | 02:29 PM
Double D's Avatar
No Speedo?
I can't get my speedometer to work. I have checked the gauge panel, it properly connected. I checked the connection at the tranny... Good. Even checked it, noted where the groove was to insert the cable, drove it, and noted that rotation of the insert in the tranny had occurred. Could it be the guage, or the cable maybe broke somewhere? Thanks.
Old May 6, 2010 | 03:24 PM
GranVille-4crawler's Avatar
Prob need the lil gear in the tranny. Mine is busted and this is the cause
Old May 6, 2010 | 03:31 PM
yotaman85's Avatar
isnt the speed sensor on the transfer case? just a thought..
Old May 6, 2010 | 04:45 PM
1990yota-pickup's Avatar
take out your dash and put your truck on jackstand and whatch cable turn while running truck in gear on jackstand in your garage...
Old May 6, 2010 | 07:06 PM
Double D's Avatar
ok i'll try this and get back to you. thanks
Old May 7, 2010 | 02:25 AM
DanStew's Avatar
Definately look at the gear thing in the Tcase. It is one screw and it pops out. Mine was eaten. Add new one and speedo worky. It is easier than tearing everything else apart unfortunately
Old May 7, 2010 | 01:34 PM
ya, while you got that dash out u can change out those old dash bulbs with some new bulbs or fix the burnt out ones
Old May 7, 2010 | 01:39 PM
i strongly recomned on what Danstew said why do all that extra work when its not nessary pulling you dash apart.. pain in the butt..
just dont make your truck fall off jacks stand while in gear and hope to god you don crash through the house.
Old May 10, 2010 | 04:56 PM
Double D's Avatar
I had already taken the dash out and gutted the interior to restore it since I just got the truck and it wasn't in the best shape. I did stuff the dash with red leds instead of the factory green. Also did the climate control lights as well. I will get pics up later when the sun goes down.
Dieselmann
Feb 19, 2019 02:57 AM
charlie_fong
Sep 27, 2015 10:06 PM
travisamorgan
Sep 2, 2015 01:00 PM
94ofCanada
Aug 14, 2015 06:37 AM
Pedalpwr27
Aug 13, 2015 06:37 AM
