1991 3.0 will not STOP running
I replaced the fuel pump in my 1991 4Runner and now it will not STOP running, possible a person helping me hooked the battery up backwards for a moment while I stepped away. all ready disconnected the alt to check that it was not a diode stuck open, it is not. only way to shut the engine down is to unplug the negative cable. ANY ideas?
Thanks for your replys.
I have allready replaced the ignition switch, and same situation. I put the origanal back in and was able to return the new one. Now it is behaving different. when I remove the key rather than running on, it stutters and misfires then stops after about ten seconds and I have a check engine light now, I am going to put a volt meter on the Batt and see if the alt circuit is shutting down when the key is removed. I belive it may be related to the ecu.
Get out the multimeter and electrical diagram and see if there's a short somewhere.
I have been trying to find the Electrical Diagram, but, have yet to find one. I am thinking there may be a transistor in the ecu that is fried (stuck in the ON position) or maby a relay controled by the ignition switch which is "welded" ON, it seems as if the ignition is in the on position when it is off, I am boggled. I am going to meter out some circuits and seach for a diagram. I really value all your feedback, Thank you all very much, we will see what is the culprit.......
Sorry, that wasn't very helpful. Try this one:
http://didnt.doit.wisc.edu/offroad/T...unne/systemci/
Pull down eng3r.pdf.
icentropy
Jul 11, 2015 07:21 AM
