Trans. leaking
Old May 7, 2010 | 07:37 PM
coronadrinker85's Avatar
Trans. leaking
hey guys I have a '87 with a 22r and it seems to be leaking from the top of the trans around the area of the stick shift. i sprayed it off a couple times with degreaser this evening so it will be cleaner when i get under there tomorrow. My question is, that the heck is up there that can be leaking? It has never leaked in the 24 years my step dad had it, now i have it and it leaks.... WTF
Old May 7, 2010 | 07:56 PM
Kiroshu's Avatar
I'm assuming its a manual? Its prob leaking out the fill plug. Pretty common on these other wise just let us know tom.
Old May 7, 2010 | 07:58 PM
yes it is a 5 speed. Is the fill plug locate on the drivers side? sorry for the dumb question, but I'm very new to these trucks.
Old May 7, 2010 | 07:59 PM
scuba's Avatar
Shift plate retainer gasket, most likely.
Old May 7, 2010 | 08:02 PM
PlanB's Avatar
x2 on that. My 22r manual is soaked up there too. Its not the fill plug on mine.
Old May 7, 2010 | 08:07 PM
Kiroshu's Avatar
Yes its on the Drivers side.
Old May 7, 2010 | 08:09 PM
hhmmm retainer gasket you say. taking a wild guess and im going to say that that's dead nuts on the top of the trans where i cant see it right?
Old May 7, 2010 | 08:12 PM
Kiroshu's Avatar
yea just take the center console out and top boot(s) and you can get to it inside the truck
Old May 7, 2010 | 08:14 PM
No kidding, man I'm loving this truck more and more every day. Is it a pain is the butt to change out (assuming that that's it)
Old May 7, 2010 | 08:15 PM
Kiroshu's Avatar
Not really. Like i said you can sit your butt right in the drivers seat and change it.
Old May 7, 2010 | 08:17 PM
cool, thanks for your help. I'm going to go check it out right now
Old May 7, 2010 | 08:29 PM
well, its sure greasy up there but its hard to tell what is what because its still wet from her bath.
Old May 7, 2010 | 08:37 PM
scuba's Avatar
Pull the shift boot, you'll be able to track it down if you can see from up top..
Old May 7, 2010 | 08:44 PM
I did, but the drivetrain is all wet and its dark out. If it is the gasket is that something they sell at autozone or is it off to the stealership for me?
Old May 7, 2010 | 09:08 PM
scuba's Avatar
Go to the dealership, it's like 5 bucks, I think you'll need two though. Just ask to look at thre diagram
I needed two for my Tacoma.
Old May 7, 2010 | 09:32 PM
one for each shifter?
Old May 7, 2010 | 09:44 PM
Kiroshu's Avatar
Yes one for the 4wd and the gear shifter
Old May 7, 2010 | 11:19 PM
scuba's Avatar
LOL.
I meant, on the transmission shift plate retainer, mine uses 2 gaskets. One on top of a little teeny aluminum plate, and one on the bottom. The gaskets sandwich the aluminum plate and then it all gets bolted in between the trans and the shift plate.
That's why I said look at the diagram that the parts guy looks at.
Old May 10, 2010 | 09:27 AM
So I called the dealer today and they are telling me its like 50 bucks because there isn't a regular gasket its something else (i forgot what he called it) is this right?
he's gone
7
Dec 3, 2019 07:08 AM
akamon808
3.4 Swaps
Dec 16, 2015 08:45 PM
TACOJO
Nov 27, 2015 05:26 PM
Tigbucket
Jul 30, 2015 07:29 PM
Avenged
Jul 9, 2015 07:55 AM
