new radio problem........
Old May 17, 2010 | 10:03 PM
CHOPER's Avatar
hey guys i need help figuring out whats wrong with my 92 toy pickup. i installed a new alpine radio and wired up everything. now the fuse kept burning out for my tail lights and my gauges. so i unpluged the harness on the radio and everything started working again. im assuming i wired a cable the wrong way. can anyone help with which cable goes where i connected the ground the constant power and found the switch by checking wich cable gave power when i turned the key. its a simple install just 4 speakers no amps or anything of that sort.
also now that da radio is unplugged and the lights work fine again now when i press the button on my alarm remote the tail lights dont flash anymore.does anyone know why?
Old May 17, 2010 | 10:40 PM
iamsuperbleeder's Avatar
looks like it's time to double check the wiring, assuming you just spliced right into the factory harness
http://download967.mediafire.com/97m...zdo/stereo.pdf
Old May 19, 2010 | 09:34 AM
CHOPER's Avatar
problem solved
hey thanks alot for the help. what happened was that i grounded the radio to a power source. it originally showed as ground but when i turned the lights on the wire had power. so i grounded the wire to the frame now all is working great. thanks for the help.
Old May 19, 2010 | 09:40 AM
MaK92-4RnR's Avatar
lol yeahh... thats a bad idea.
kawazx636
Oct 6, 2021 03:03 PM
mct75
Aug 22, 2016 01:24 PM
zombie_barbarossa
Oct 2, 2015 10:54 PM
tazman1972
11
Sep 28, 2015 10:32 PM
ctheiss
Sep 14, 2015 12:18 PM
