Bout to give up on my 94 toyota
Old May 16, 2010 | 09:43 AM
dcmbsc's Avatar
about 1 year ago when driving my truck to school. The check engine light came on and I lost alot of power,turned around and went home. I did the paper clip and found a code 52 , knock sensor. Went in over time and replaced it. Put it all back together and it would not run... after a couple of months found it was the timing was 180 out and got her running.
Now after all I did, soon as I drive around for a couple of minutes the engine light comes back on and I lose all power once again. Throws the code 52 again and sometimes says no codes.
Err....
Old May 16, 2010 | 10:16 AM
hilandfrog's Avatar
The wires or the ECU are the next steps in the chain I think???
Repo
Old May 16, 2010 | 10:20 AM
Kiroshu's Avatar
Is it a 3VZ(3.0)? They are bad for the whole wiring harness for the knocksensor buring up just buy it from toyota and repalce it. You sould be fine after that.
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Cplmike
Jul 8, 2015 08:47 PM
Jnkml
Jul 6, 2015 01:20 PM
Suprarossa
Jul 6, 2015 05:21 AM
