need help quick! filling transfer case
Old Sep 16, 2013 | 12:16 PM
Sandman's Avatar
I have the shifters off and I poured the oil through the top...it's not coming out the bottom and it's about to overflow at the top where the shifter plate cover is....what?????? what do I do!!!??
Old Sep 16, 2013 | 12:22 PM
big bear's Avatar
I was temped to try that, but pumped it in the filler hole instead.
Don't know what to tell you man, maybe it will go down if you wait a bit.
Stetson_md's Avatar
http://www.trail-gear.com/assembled-t-cases-info <-- this is where you fill it second picture Turkey baster might be able to pull out some of what you put in
Old Sep 16, 2013 | 12:31 PM
Sandman's Avatar
I just put 3 qts in where the 4wd shifter is...not coming out the bottom...where is it going ?
Old Sep 16, 2013 | 12:34 PM
big bear's Avatar
Three quarts ??
Are you using Hayes manual ?
Old Sep 16, 2013 | 12:44 PM
Sandman's Avatar
I just filled the transmission this way...just left the filler hole open until the oil started coming out...next did the transfercase and kept adding but it never came out the hole!!!
Old Sep 16, 2013 | 12:50 PM
osv's Avatar
osv
you have a forward-shift transmission, which has a big empty cavity underneath the transfer case shifter... the only time that there is fluid in there is when the rear seal on the trans is leaking... you just can't tell that it's leaking, because whatever leaks is sealed up in that big cavity... it's a stupid design.
if you look into the hole where the shifter was, you can see where the end of the shifter fits in the rod that goes back to the transfer case.
siphon out the gear oil, take the flat plate off of the transfer case directly behind the transmission, and put the gear oil in there.
Old Sep 16, 2013 | 12:54 PM
Sandman's Avatar
thanks osv! wasn't expecting this!!! Now I have to figure out how to pump it out..sheesh
Old Sep 16, 2013 | 01:07 PM
osv's Avatar
osv
harbor freight or an auto parts store should have one of those cheap siphon pumps that you squeeze to get the flow started... not sure how well it'll work with thick gear oil? you may have to use a bigger diameter one.
once you have the pump, you could use it to put the gear oil in at the proper fill plug, that Stetson linked to.
4x4-runner
Dec 27, 2016 01:58 PM
Chumlee780
Nov 13, 2015 03:18 PM
Mike Maiato
Aug 28, 2015 02:35 AM
yourrealdad
Jul 29, 2015 11:08 AM
crashburnoveride
Jul 10, 2015 06:39 AM
