can't stop power steering pump leak
I'm having issues with mine as well. Used all toyota parts but its still leaking. Looks horrible with that fluid everywhere. I'm in the middle of a 5 speed swap, ome suspension and por-15 treatment so the pump will have to wait a bit.
If it only leaks under pressure, it's probably the "banjo" fitting where the high pressure line attaches to the side of the pump. I stopped mine from leaking there by applying a thin layer of hi temp RTV to both sides of the fitting, reassembling it, and letting it cure for 24 hours before starting the engine and applying pressure to it. Don't use too much; you don't want it to get into the valve mechanisms.
06-01-2021 01:51 PM
icentropy
07-11-2015 07:21 AM
Avenged
07-09-2015 07:55 AM
Jnkml
07-06-2015 01:20 PM
