Driveline vibrations? Here's how you fix them. (video)
Old 09-20-2013, 07:10 PM
arlindsay1992's Avatar
Sometimes when lifting a truck you end up screwing up the pinion angle. When I installed my OME leaf springs, I had no vibrations at all. My problem arose when I installed my BudBuilt crossmember. They are listed as no drivetrain lift but they do, in fact, lift the drivetrain just a little. There are no clearance issues with stock trans and body heights but it does throw off the pinion angle. Regardless of the cause, this video I made shows how to measure the pinion angle and what is necessary to solve it. Keep in mind, worn u-joints, unbalanced tires, and a number of other things can cause vibrations. In any case, I hope this video helps you out. I also have step by step videos showing the OME spring install, the BudBuilt crossmember install, and many other Pickup/4Runner 22RE how to videos.
Old 09-21-2013, 08:10 AM
osv
osv's Avatar
nice work, I think that you covered all of the major points.
nvdesertrunner
05-11-2020 08:18 PM
crammit442
7
11-29-2017 12:30 PM
justdifferentials
Just Differentials
08-15-2015 05:25 PM
mbomberz1
08-08-2015 06:57 AM
RobotMoose
Diesel Swaps
08-02-2015 11:00 PM
Quick Reply: Driveline vibrations? Here's how you fix them. (video)
