22re acting up please help
Old Aug 29, 2013 | 03:19 PM
yota8888's Avatar
I have a 22re that starts right up cold drives fine sometimes farts a little theb when i start back up it cranks forever and i have to pump gas to get it going then last time its even harder to start even when cold ran it for 3 min and exhaust was red hot but engine wasnt abd had to keep it high rev to run
Old Aug 29, 2013 | 04:38 PM
Rerunn's Avatar
Cold start injector time switch
Old Aug 29, 2013 | 05:00 PM
yota8888's Avatar
Its a 1987 truck 4x4 that sitch could cause all that?
Old Aug 29, 2013 | 05:07 PM
Rerunn's Avatar
Yep there is a tsb for it
Old Aug 29, 2013 | 05:21 PM
yota8888's Avatar
Ok thanks
Old Aug 29, 2013 | 05:56 PM
Kiroshu's Avatar
x2 on Cold start injector Circuit.
Old Aug 30, 2013 | 12:34 PM
yota8888's Avatar
The cold start injecter switch wasnt it any other ideas thanks
Old Aug 30, 2013 | 12:45 PM
john22rebuilder's Avatar
I had a bad plug wire that wouls short when hot couldnt see it but could hear it. At highway speeds(i assume) the injector on the dead cyl still dumps gas and it would get burnt up at the cat and muffler mine got so bad both glowed red!!!! Taped the wire till i could buy wires problem dissapeared . Try it at night spsrk could be visible....
Old Aug 30, 2013 | 12:49 PM
yota8888's Avatar
Ok i cut the cat off now so the exhaust isnt screwing with iti have a spaer efi set i was gonna start swapping sensors
Old Aug 30, 2013 | 05:55 PM
Kiroshu's Avatar
Cold Start Injector malfunction... leaking...?
Coolant Temperature Sensor(ECT) malfunction...?
Doug4320
Mar 24, 2018 10:11 PM
wafoogalla
Nov 2, 2016 11:02 AM
HollieJayyy
Aug 9, 2015 07:59 AM
Nickyodaman
Jul 27, 2015 12:13 AM
jgallo1
Jul 22, 2015 04:21 AM
