what's this noise? (video attached)
Old Aug 31, 2013 | 10:53 AM
ridewrapper's Avatar
http://static.photobucket.com/player...psaa0a327b.mp4
What is making this noise?
Please turn volume up.
Old Aug 31, 2013 | 11:03 AM
Cyberman's Avatar
It's a squeak.
Seriously, is it on that side? Try spraying some lube right between the axle and the backing plate to see if it goes away. Maybe a dry seal?
Old Aug 31, 2013 | 11:06 AM
Yeah its just on the passenger side. I'm hoping its not a bearing
Old Aug 31, 2013 | 11:48 AM
Cyberman's Avatar
If its a bearing, there should be some lateral play in the axle.
Old Aug 31, 2013 | 12:00 PM
Teuf's Avatar
Bearing easy to do. Go for it.
Old Aug 31, 2013 | 12:15 PM
Cyberman's Avatar
Well somewhat easy. If you do go for it, get new oil seals too.
Old Aug 31, 2013 | 04:18 PM
Zero lateral play. I just move it a smidge and it squeaks. Must be just a squeak as cyberman said.
Its the rubber peice just behind the hub. I cleaned it off and lubed it up but no luck getting rid of the squeak.
Old Aug 31, 2013 | 05:12 PM
Kiroshu's Avatar
Sounds like excessive seal friction. Unless the seal is damaged. Lube is your friend.
-Check differential fluid level.
Old Aug 31, 2013 | 05:30 PM
I sprayed WD40 in there, didnt pull it apart. Just cleaned the dust and squeezed the WD40 tip ino the rubber and it still squeals. Maybe grease is better?
Old Aug 31, 2013 | 05:53 PM
rworegon's Avatar
WD40 is a better degreaser than lubricant, IMO.
Old Aug 31, 2013 | 05:59 PM
What is a better lubricant then?
Old Aug 31, 2013 | 06:05 PM
rworegon's Avatar
Grease. Or, something like Tri-Flow.
Old Aug 31, 2013 | 06:08 PM
Cyberman's Avatar
If you don't mind bleeding your brakes, you could pull the axle on that side and see if it still squeaks while its off the truck...
Old Aug 31, 2013 | 06:27 PM
ksti's Avatar
^^^X2
Just pull the axle, it's not that hard and make sure your not gonna have a bigger problem in the future.
JNapolitano
Nov 14, 2019 07:46 PM
Jcrawl94
10
Oct 24, 2015 04:34 PM
Shaun Crystal Gomban
Aug 2, 2015 08:00 PM
razorman8669
Jul 12, 2015 12:13 PM
mlavery85
Jul 12, 2015 10:33 AM
