Replacing TPS
Old Sep 21, 2013 | 11:10 AM
SqWADoosh's Avatar
Replacing TPS
I have been plagued with a high idle and have finally diagnosed it to be a faulty TPS. I'm wondering if I am able to buy a new one from LCE and just do a straight swap with my current bad one or if there is any calibration required? It looks as though its as simple as unplugging it and removing the two screws that go into the throttle body. Any help as always is much appreciated. Thanks guys.
Old Sep 21, 2013 | 12:05 PM
scope103's Avatar
The two screws fit into slots so that you can rotate the TPS ... to calibrate it. So yes, if you replace the TPS you must adjust it.
How did you determine it was a faulty TPS?
Old Sep 21, 2013 | 12:40 PM
SqWADoosh's Avatar
Because by tapping on the tps the idle comes back down. Which I found as a diagnosis on here. It is also throwing the code related to tps
What is the process for calibrating it?
Old Sep 21, 2013 | 02:30 PM
aztoyman's Avatar
4Crawler has a good write up on adjustment for 22RE. I think it is easiest when you have the throttle body off when you do it.
Also a good time to replace the mounting screws with socket head type.
Just Google 22RE TPS adjustment.
smthwsn357
May 1, 2024 07:28 AM
Sleaker
Aug 26, 2020 06:03 AM
mskalmus
May 28, 2017 07:51 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
1994toyota
Jul 17, 2015 03:03 AM
