Bad Oil Pressure Gauge
1991 DLX ExtraCab Pickup
22RE, 5 speed
The gauge quit working. I found one of the leads from the sensor broke at the bayonet type connection. I spliced them back together, no pressure indicated. I replaced the sensor and still no gauge movement.
Suggestions?
22RE, 5 speed
Suggestions?
I would say poor splice .
Did you solder the splice??
Did you also install a new connector.
They get corroded quite easy that you might not see with the naked eye.
Most all the electric oil pressure gauges I have seen just on wire just what did you try and repair??
Sep 4, 2015 09:27 AM
Poncho0206
Jul 10, 2015 06:21 PM
