Bad Oil Pressure Gauge
Old Sep 2, 2013 | 09:02 PM
owenskp's Avatar
1991 DLX ExtraCab Pickup
22RE, 5 speed
The gauge quit working. I found one of the leads from the sensor broke at the bayonet type connection. I spliced them back together, no pressure indicated. I replaced the sensor and still no gauge movement.
Suggestions?
Old Sep 3, 2013 | 12:07 AM
wyoming9's Avatar
Red face
I would say poor splice .
Did you solder the splice??
Did you also install a new connector.
They get corroded quite easy that you might not see with the naked eye.
Most all the electric oil pressure gauges I have seen just on wire just what did you try and repair??
Old Sep 3, 2013 | 05:27 AM
owenskp's Avatar
Splice
I couldn't use the old OEM connector since the wire was broken off right at the connector. I just used a straight butt splice....nothing fancy, just trying to make a connection.
Old Sep 3, 2013 | 07:08 AM
scope103's Avatar
http://personal.utulsa.edu/~nathan-b.../6combinat.pdf
page BE-37
bigjstang
Jun 2, 2025 03:56 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
Sep 4, 2015 09:27 AM
Poncho0206
Jul 10, 2015 06:21 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
