sunroof= no map light switch?
Old Sep 15, 2013 | 07:31 AM
vasinvictor's Avatar
I just realized that my 95 4runner with a sunroof does not have the switch to turn the map lights on when the door is open. I also have a '94 that does not have a sunroof. It does have this switch.
Can anybody confirm that models with a sunroof didn't get this switch? I guess the issue would be a lack of room to route wires because of the sunroof?
Old Sep 15, 2013 | 11:11 AM
scope103's Avatar
When I open my door the dome light comes on. When I work the switches, the map lights come on. I not aware (I have the sun roof) of any switch that couples the map lights to the dome light. (The map lights aren't THAT close to the sunroof, so room for wires couldn't possibly be an issue. The map lights have power wires; you're just talking about an additional wire to bypass the map light switch.)
Or, I have no idea what you're talking about. Take a picture.
Old Sep 15, 2013 | 11:25 AM
RJR's Avatar
RJR
He's referring to a switch that allows you to select whether or not the map lights come on when you open the door. My '94 with sun-roof does have this switch. It's right between the two map light switches. I would guess it's more a matter of which trim package you have. Mine is the SR5 leather seat version, so it's probably the top of the line trim package. (I didn't buy it new, so I don't know for sure. I did buy it from a doctor, however.)
Old Sep 15, 2013 | 05:54 PM
^ That's what I wanted to hear. I also have SR5 and leather, but I do not have that switch... Mine's a '95, however. Wonder if it's a '94 vs '95 thing? I'm going to try to pull mine out and see if I have a "switched ground" under there and swap the two. It's night and day difference with those map lights at night time.
Old Sep 15, 2013 | 06:07 PM
http://www.ebay.com/itm/1989-95-Toyota-4Runner-SR5-Oak-Tan-Map-Light-Rear-View-Mirror-/141059120385?pt=Motors_Car_Truck_Parts_Accessories&hash=item20d7c75d01&vxp=mtr
http://www.ebay.com/itm/1989-95-Toyota-Tacoma-4Runner-SR5-Oak-Tan-Map-Light-Rear-View-Mirror-/141059119799?pt=Motors_Car_Truck_Parts_Accessories&hash=item20d7c75ab7&vxp=mtr
For example...
Old Sep 15, 2013 | 10:35 PM
Gamefreakgc's Avatar
Looks like you need to hit up the junkyard! Would be an easy install, it should not require any additional wiring.
Old Apr 22, 2014 | 07:40 AM
Just wanted to update this... I had no "door open, map lights come on" switch on my loaded 4runner. I got a unit with a switch from the pick n pull. Swapped units, and it works perfectly. Doors open, map lights come on. No additional wiring like ^ this guy said. Just wanted to give future searchers some resolution.
Scope, you gotta do this man, it's really such a unbelievable difference at night.
Old Apr 22, 2014 | 06:30 PM
Put some 12x LED's in there like I did and it'll be really bright! I can see every corner of my cab with those things.
Old Apr 22, 2014 | 06:32 PM
I would love to, but every time I read about LEDs they are crappy and burn out after a short while. My incandescent are probably still original! What brand do you recommend?
Old Apr 22, 2014 | 11:47 PM
wyoming9's Avatar
Red face
Now on my 92 4Runner SR5 I have the map light switch and a sun roof
Since I keep the switch turned off it is not really important
Old Apr 23, 2014 | 08:56 PM
I bought these:
Amazon.com: 2pcs 31mm 12-SMD 1.25" 12V Festoon Dome Light LED Bulbs + STICKER DE3175 DE3022 DE3021 3175 - White: Automotive Amazon.com: 2pcs 31mm 12-SMD 1.25" 12V Festoon Dome Light LED Bulbs + STICKER DE3175 DE3022 DE3021 3175 - White: Automotive
LED's last longer than regular lightbulbs and use less energy (meaning if you leave the light on it'll take much longer to kill your battery... saved my bacon once).
Old Apr 24, 2014 | 03:26 AM
Zach1993's Avatar
What are good websites to get head lights from?
coreyedwards7611
Jan 16, 2016 06:38 PM
fountain
Dec 31, 2015 06:08 AM
B1gR3d
Aug 1, 2015 10:10 PM
TDonkey
Jul 26, 2015 10:14 AM
Johntom240
7
Jul 13, 2015 12:18 AM
