PCV causes a smoking tailpipe.
Old Sep 2, 2013 | 04:38 AM
InToxicOne's Avatar
So I've been running here in CA for a few months without any PCV hooked up and I figured it'd be smart if I get pulled over to hook it back up (even though I know they wont inspect under my hood for it). So I go and buy a new PCV and hooked up the lines. Now when I put the car under boost pressure it smokes like a chimney but it only seems to happen when boost pressure kicks in. I disconnected it and plugged the vacuum line again and no smoke... Anyone got ideas on whats wrong with this thing?
Old Sep 2, 2013 | 06:52 AM
Kiroshu's Avatar
Engine...?
Cylinder head cover baffle plates missing and or damaged inducing oil into intake...?
PCV valve stuck open/closed...?
Incorrect PCV valve...?
Old Sep 2, 2013 | 06:59 AM
InToxicOne's Avatar
Its not the engine from what I could tell. No loss of power and pretty low HC levels (under allowable levels) in the oil. My guess is its not stuck open or I'd be blowing the valve cover gasket. The pcv is brand new so it shouldn't be bad I hope. Seems kinda odd.
dzldust
7
Oct 6, 2015 05:39 AM
shredder4286
Oct 1, 2015 01:09 PM
puddlepirate
Sep 29, 2015 08:02 PM
voiddweller
Sep 28, 2015 11:21 PM
charlie_fong
Sep 27, 2015 10:06 PM
