1992 Toyota Pickup Keyless Entry Install
Old Dec 11, 2020 | 06:30 AM
My'lil'truck's Avatar
I'm installing a keyless entry system in my 1992 4WD truck. Where is the best place to connect in the right and left turn signals? Thanks!
-J
Old Dec 13, 2020 | 01:06 PM
scope103's Avatar
I don't know if I used the best place, but I picked them up at the connector right under the steering column.
While I have your attention, how to you plan to connect to these signals? The dreaded "vampire tap"? I thought I got a much more reliable and cleaner looking connections with barrel crimps.
You remove the connector pin from the body. Remove a ~4mm piece of insulation
Then use a barrel crimp (with crimping tool) to attach your wire to your Entry computer. (True barrel crimps are a little hard to find; I just cut them off a set of fork connectors I already had).
Cover the crimp with heat-shrink, re-install the connector pin to the body, and you have a very reliable, compact connection.
Old Dec 14, 2020 | 06:31 AM
Smile Worked Perfectly
Hey thanks. That did the trick. I connected in in the same location. I wasn't able to find the barrel crimp connectors, so I cut the wire about 1 in behind the plug and used standard solderless connectors. Seems solid and everything is working well. Next project is cruise control. Any advice on good kits?
Thanks Again,
-Jim
merace19
Mar 1, 2009 10:47 AM
Jeff_M
15
Sep 19, 2005 05:17 PM
nfenwick
Aug 9, 2004 01:02 PM
ruizs
Mar 17, 2004 09:35 PM
