1992 Toyota Pickup Keyless Entry Install
I'm installing a keyless entry system in my 1992 4WD truck. Where is the best place to connect in the right and left turn signals? Thanks!
-J |
I don't know if I used the best place, but I picked them up at the connector right under the steering column.
https://cimg1.ibsrv.net/gimg/www.yot...58e5f3db4e.png While I have your attention, how to you plan to connect to these signals? The dreaded "vampire tap"? I thought I got a much more reliable and cleaner looking connections with barrel crimps. You remove the connector pin from the body. Remove a ~4mm piece of insulation https://cimg0.ibsrv.net/gimg/www.yot...9bb9273398.jpg Then use a barrel crimp (with crimping tool) to attach your wire to your Entry computer. (True barrel crimps are a little hard to find; I just cut them off a set of fork connectors I already had). https://cimg6.ibsrv.net/gimg/www.yot...bae2d1cd3d.jpg Cover the crimp with heat-shrink, re-install the connector pin to the body, and you have a very reliable, compact connection. https://cimg9.ibsrv.net/gimg/www.yot...7fb74ca73f.jpg |
Worked Perfectly
Hey thanks. That did the trick. I connected in in the same location. I wasn't able to find the barrel crimp connectors, so I cut the wire about 1 in behind the plug and used standard solderless connectors. Seems solid and everything is working well. Next project is cruise control. Any advice on good kits?
Thanks Again, -Jim |
