87 4Runner - How are RH and LH ball joints different?
Old Dec 1, 2020 | 07:09 PM
CCDave's Avatar
Made a mistake and mixed up the new OEM ball joints for my 87 4Runner after taking them out of their bags. Each upper and lower has a unique part # suggesting RH and LH ball joints are different, but both uppers look the same and both lowers look the same. How do I tell which are the RH and which are the LH?
Old Dec 1, 2020 | 08:14 PM
millball's Avatar
I recently bought and installed new genuine Toyota ball joints on my '87 Runner.
Best I could determine by examination, manipulation, and measurement, was that the only difference between the left and right ball joints is the positioning of the rubber boot
so that the little tit on the boot that permits excess grease to bleed out of the boot; faces toward the rear of the truck.
I'd be interested in any information that says other differences exist. I could'nt find any.
Old Dec 2, 2020 | 02:10 AM
CCDave's Avatar
Originally Posted by millball
Best I could determine by examination, manipulation, and measurement, was that the only difference between the left and right ball joints is the positioning of the rubber boot so that the little tit on the boot that permits excess grease to bleed out of the boot; faces toward the rear of the truck..
I just checked mine and see what you're referring to. If no other info is out there, I'll use the nip location to pick which side to install them on. Appreciate the help.
pacific5th
May 25, 2020 08:51 AM
SCRunner12
Dec 26, 2013 10:42 PM
pjmags
Jul 9, 2012 05:15 PM
Lankan
Jun 13, 2012 01:22 PM
timfields45
Mar 31, 2012 06:20 AM
