Cooling and Heating fan issue
Old Jan 12, 2021 | 10:58 AM
Ralphthe4runner's Avatar
So my 91 4runner seems to have an issue with controlling the in cab temperature. Starting from the off position I'm able to click to the right 3 times when it seems like it should be 4. Starting from off(1), LO(2), first dot(3), second dot(4), HI(5). So it looks like my slider only goes to the second dot or 4. I've taken off the lower dash and face plate and inspected the switch and from that look everything seems to be in working order, nothing impeding it. So could there be another reason why the switch will not go all the way to HI.
Another problem is the AC light when activated will only light green when I it's on LO. Not either dot. Also neither dot allows the fan to blow.
Im owner number whatever so I'm not sure what everything originally looked like nor how it worked. Thanks in advance for any advice.
tjhurst
Feb 25, 2015 07:08 AM
kwnate
Nov 28, 2010 08:28 AM
az4x4runner
Jul 28, 2010 07:08 PM
HupDogDaddy
Nov 15, 2008 08:27 PM
Marc
Jul 2, 2004 10:40 AM
