Starter jump solution?
Old Nov 16, 2020 | 09:49 AM
NMDesertRat's Avatar
I've been having some issues with randomly having to tap my starter solenoid to start it up. I replaced the contacts way back in the day, so this isn't the standard click no start issue. But, as of this morning, the only way to start my 86 4runner is to turn the key to start then jump the solenoid spade straight to the battery. I tap, tap, tap all day and it isn't enough. But, it starts right away when I jump it. Does this mean I just need to break down and replace/rebuild that solenoid now? Or is there something else in line, like a relay, between the ignition and the plug that triggers it?
Thanks!
Old Nov 16, 2020 | 10:19 AM
2ToyGuy's Avatar
Try reading the first post in THIS THREAD. It may explain your trouble, how to verify it, and how to fix it.
Good luck!
Pat☺
Old Nov 16, 2020 | 10:43 AM
scope103's Avatar
Originally Posted by NMDesertRat
... Does this mean I just need to break down and replace/rebuild that solenoid now? ...!
No. Your problem (this time) has nothing to do with the solenoid.
... Or is there something else in line, like a relay, between the ignition and the plug that triggers it?...
Uh, maybe. For that answer you need to read https://www.yotatech.com/forums/f116...runner-307493/ . According to Rad4runner (who seems to know) some trucks of your vintage may have a starter relay. If you don't have one, he (she?) tells you how (and why) to install one.
Old Nov 16, 2020 | 12:44 PM
Blueman's Avatar
My '87 went through a period of life when it used to do this. It was more common when the weather was cold, and there was a seemingly random delay from turning the key until the starter would start to crank. Sometimes instantly, and sometimes several seconds of delay. Solution was to replace the starter -- then all was better.
As a side note, there are two starter options for this truck, apparently. One for cold climates and one for "normal".
Old Nov 16, 2020 | 12:51 PM
Ok. I thought it was triggering every time with the Rad4Runner jumper. I took the solenoid off while waiting for a reply (had some time) and cleaned it up, replaced a funky contact that was a worm a bit wonky, shined up plunger and such, now it's not kerchunking at all when I jump it. There is NOT energizing. Why would that be?
Old Nov 16, 2020 | 03:15 PM
Figured it out. Pulled it off again, did a test with jumper cables and it didn't do jack. AZone tested it and it was bad. 244k miles seems to be it's dead date. Probably my fault though. I spray it pretty good with cleaner and I may have shorted something.
Changed it out with a Duralast. Kept the core. Gonna take it a part and o a post mortem on it tomorrow. Maybe rebuild it as spare. I couldn't bare to part with the OE from my sweet, sweet Ivana.
Old Nov 16, 2020 | 04:59 PM
swampedout's Avatar
5 Year Member
Good call keeping the core. Youre gonna kick yourself when the duralast goes out
Old Nov 16, 2020 | 05:10 PM
wallytoo's Avatar
rad is Ray, a "he".
Old Nov 17, 2020 | 09:50 AM
RAD4Runner's Avatar
@NMDesertRat , Please save everybody's time and indicate model-year-engine-transmission-trim, etc.
If earlier model truck auto it does not have a start3r r3lay - BAD.
If manual the start3r r3lay was wired wrong at the factory
Originally Posted by wallytoo
rad is Ray, a "he".
LOL!
Old Dec 2, 2020 | 07:28 PM
coopster's Avatar
From: exo-reality -wave if you see me; Front Range, CO
Oh man. And so now with the 'pronouns' on yotatech I guess.
j/k. I'll have a hot cup of ˟˟˟˟ thank you very much!! LOL
crookchad
Oct 23, 2018 02:23 PM
SubiKing
Nov 25, 2015 12:50 PM
highplainsdrifter
7
Feb 4, 2013 09:46 AM
brysawn
Dec 24, 2011 04:04 PM
halza
Nov 19, 2004 09:35 PM
