No crank no start
Old Oct 23, 2018 | 08:04 AM
crookchad's Avatar
No crank no start
My 1985 4runner has started to have an issue where you turn the key and it just clicks like a dead battery, but the battery is good, and has charge. Sometimes if I cycle the key a few times it will then crank and start fine. Now it wont start at all. I am sure it is something to do with the starter, but it might not just be the starter right? It could be a weak connection? Any ideas before I replace the starter?
Old Oct 23, 2018 | 08:34 AM
L5wolvesf's Avatar
It sounds like what happened to mine. 30+ year old wiring and related parts. I added a starter relay to mine (what Toyota did on later years) and no problems since.
Search for "starter relay" in this or the 86 forum - look for posts by RAD4Runner (our electrical guru here). It is a very easy upgrade.
But first make sure all your contacts and grounds are clean bright shiny metal to bright shiny metal and tight.
Old Oct 23, 2018 | 02:23 PM
millball's Avatar
If the click is coming from the starter itself, it's likely the main contacts in the starter selenoid that need attention.
5.9ford
Dec 6, 2012 05:20 PM
hermyboy3000
Aug 19, 2012 12:19 AM
scharp
Mar 8, 2009 11:00 PM
spooniepjfd
Jan 20, 2009 09:07 PM
Crash_AF
Jun 8, 2006 10:08 AM
