No crank no start
No crank no start
My 1985 4runner has started to have an issue where you turn the key and it just clicks like a dead battery, but the battery is good, and has charge. Sometimes if I cycle the key a few times it will then crank and start fine. Now it wont start at all. I am sure it is something to do with the starter, but it might not just be the starter right? It could be a weak connection? Any ideas before I replace the starter?
It sounds like what happened to mine. 30+ year old wiring and related parts. I added a starter relay to mine (what Toyota did on later years) and no problems since.
Search for "starter relay" in this or the 86 forum - look for posts by RAD4Runner (our electrical guru here). It is a very easy upgrade.
But first make sure all your contacts and grounds are clean bright shiny metal to bright shiny metal and tight.
5.9ford
Dec 6, 2012 05:20 PM
