Speed sensor interchange/ 92 4r
Old Mar 4, 2014 | 11:30 AM
juanschwartz's Avatar
Question Speed sensor interchange/ 92 4r
Hello, and apologies for not submitting a proper introduction (if there is a thread to do so). I've got a 92 4r sr5 with the 3.0 and an autotragic trans. apparently, someone along the way changed the tc on it (to a chain driven unit if i have read correctly), so now ive got a cable speed sensor and a dangling wiring harness, not to mention no working speedo or odo. i am aware of the marlin crawler adapter, which if i understand correctly, would fix my issue, but i am wondering A) what my options are for just replacing the sensor, and B) if someone has one laying around that they would part with for a reasonable sum. any help on identification/ interchange info would be most appreciated.
**edit:*** yes, i searched, and found nothing of use.
Old Mar 4, 2014 | 12:12 PM
blake.nemitz's Avatar
why not take one from the salvage yard. v6 5 speeds came with a chain drive case. gear drive is only the 4cyl manual cases
Old Mar 4, 2014 | 12:19 PM
ive checked *most* yards around here, and have yet to find a single option. ive even looked for supercharged previas, as they apparently share the speed sensor. all with no luck. Thanks also for the clarification on the t/c's. my only previous yota 4x4 experience was with an fj80 series land cruiser, so im still acclimating to codes/ options/etc....
Old Mar 4, 2014 | 12:59 PM
let me look in my box. i have a spare trans that might have the sensor on it. if i still have it its all yours for 20 bucks paypal. better than 214.00 from napa.
napa link
http://www.napaonline.com/Catalog/Ca...048_0257349845
is the sensor in the trans or tcase. i have the speed sensor that goes in between the two on the trans output and is on the tcase housing right where it bolts to the trans. not the gear driven unit on the tcase.
Old Mar 4, 2014 | 02:28 PM
It's the gear driven unit. Thanks anyway.
krimsonone
Sep 13, 2024 09:33 AM
montanatruck
Feb 26, 2017 07:07 AM
ty1er
Aug 1, 2015 11:53 PM
wilbertd
Jul 6, 2015 07:39 AM
karbin
Jul 5, 2015 11:37 PM
