3.0 Will not restart after starting
Old 03-02-2014, 03:01 PM
POS 89 3VZE's Avatar
Hello all, Have a 89 3.0L V6. Recently did an engine swap with a 94 3.0L 4-runner engine. When I go out to start the engine cold, it starts right up no problems. If I let it run for more than 5 minutes and shut it off then it does not restart. It will crank and I have spark but no fire. If I spray some starter fuel in the brake line then it will turn over and keep running. Otherwise I have to wait 5 hours until the engine cools down, then it will restart again. Any thoughts? Figured it had to be a sensor, but not sure which one to look for. Is there any reason the computer would tell the injectors not to fire when it is warm?
Charecter1
11-06-2023 10:08 AM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
MTLroadierunner
07-15-2015 12:58 PM
Roger Borba II
07-09-2015 05:05 PM
raiderhawks00
07-08-2015 06:23 PM
Quick Reply: 3.0 Will not restart after starting
