Headlights dim for fraction of a second
Old Mar 7, 2014 | 05:40 AM
4mydogs's Avatar
when I brake, when I turn on a turn signal, when I shift into reverse...
This just started overnight. The headlights dim noticeably for just a fraction of a second, then return to normal. Not a huge problem, but it's annoying and the fact that it just started doing this means that something's off. Battery is only a few months old and tests strong, and the alternator is charging according to my tester. Any thoughts on what to check?
Old Mar 7, 2014 | 08:57 AM
wyoming9's Avatar
Red face
First thing look for a loose belt or corroded battery terminals.
Colder Temps will cause charging issues.
Another thing to check is the wire coming off the B terminal of the alternator they get old and brittle and strands start to break.
I would maybe upgrade your ground cables if it has never been done.
Get much Snow I drag so much onto the floor it can`t help but get into the fuse block
Been kicking the fuse block I do with my big feet once in a while I will have electrical problems.
Old Mar 7, 2014 | 09:36 AM
Gamefreakgc's Avatar
Seeing that you have aftermarket fog lights, might want to double check that wiring for problem areas.
Old Mar 7, 2014 | 09:40 AM
JasonYota's Avatar
Mine does what you describing only when I shift to reverse. My volt meter drops for a split second. When one of them goes out I'm replacing them with LEDs
Old Mar 7, 2014 | 09:48 AM
xfactor203's Avatar
Yeah, check connections. I just went through something similar and it was a bad connection at the + battery terminal.
Old Mar 7, 2014 | 11:09 AM
4mydogs's Avatar
Good ideas. Thanks.
Old Mar 7, 2014 | 02:17 PM
The volt meter moving isn't necessary a problem. Might ticks back and forth with my blinkers on or when turning on/off headlights but it does not affect anything else.
Old Mar 8, 2014 | 11:07 AM
JasonYota's Avatar
True, I didn't say it was a problem, just saying mine had similar symptoms as the OP's vehicle. Normal when you increase or decrease the load on the electrical system
Old Mar 8, 2014 | 04:30 PM
cobolt23's Avatar
All my issues of dimming lights, dancing voltmeter and other issues (windows going up deadly slow) went away the second i started my truck after doing the "BIG THREE", but I did 3 more 8ga. grounds to motor, trans, frame. 4ga for the other 3. I used welding wire from tractor supply. Good price and pure copper, not copper clad aluminum.
4banginRunner
Nov 13, 2015 05:23 AM
Chicken12
Oct 14, 2015 03:54 PM
mreagen
Oct 5, 2015 04:27 PM
beltcutter
Sep 30, 2015 06:14 AM
JPV
Sep 28, 2015 03:15 PM
